Thread: Animated Lower Third
    Jul 2015
    Kirkland, WA
    145
    What's the easiest way to make an animate lower third to use with LiveText? I have a Story Blocks lower third that I like but can't get it into LiveText. Do I have create a macro to combine two buffers, one with the mp4 and the other with the .cgxml text?
    Thanks!
    Rob Safran
    Share Wisdom Network
    [email protected]
    TriCaster: 460 AE
    TalkShow: VS4000
    Gnural Net CM & LTA
    VSE and LiveText
    Cameras: 2-Sony PMW-X70, Sony PXW-Z150
    May 2004
    Vancouver, WA
    1,585
    That's basically what you would need to do. LiveText doesn't support animation files. Just make sure the movie you are trying to use contains an alpha channel too. You mentioned MP4, which wouldn't. You'd have to also chromakey that kind of file.
    Kris
    Replay: 3Play 820
    Cameras: Sony NX5
    19,649
    Quote Originally Posted by kltv View Post
    There's one missing step here, sorry. You can't drop an animation clip in a Buffer, although you could use a Media Player instead. To use it in a buffer, you need to convert the animation to an Animation Store file using ASC, which is included in TriCaster's Add-On applications.
    Jul 2015
    Kirkland, WA
    145
    Thanks Kris and Steve!
    Rob Safran
    [email protected]
    TriCaster: 460 AE
    TalkShow: VS4000
    Gnural Net CM & LTA
    VSE and LiveText
