Results 1 to 15 of 15
Thread: System restore questions...
    Dec 2017
    UK
    35
    I have a Tricaster Mini HD-4(AE2) and Tricaster 410(AE3) and a couple of questions.
    1/ Recently I rebuilt the TC mini from the restore partition and updated Windows along the way with all the latest updates not knowing at this stage that this is not advised.
    Do I have to repeat all this without the Windows updates or is it okay to leave as is? What problems should I be looking out for?
    2/ I also rebuilt my TC-410 from the restore partition and all goes well until I get to AE3 and receive the message in the the attachment Click image for larger version.
    Can anyone help me with this? If I click 'abort' it removes all TC files from my system drive! 'retry' does nothing and 'ignore' completes the install but with warning messages!
    Any help or advice on either issue will be greatly appreciated...
    1. Windows Updates are not require and disabled by default on Windows 7 systems, but you can install them if you wish.
    2. Press Ignore, that is the SpeedHQ codec which appeared to be in use, but it should be okay.
    Dec 2017
    UK
    35
    Thanks Kanep.
    The reason for performing the system restore on the TC410 was after installing AE3 it wrongly identifies itself as a TC1.
    Newtek live chat support advised I restore it. So I have and it still thinks it is a TC1!
    Have you seen this behaviour before?
    It says this in the About TriCaster information on the home screen? I don't have a TC410 to test.
    Dec 2017
    UK
    35
    Kanep, that reports correctly Click image for larger version.
ID:	147082 but when I run updates it comes back with updates for a TC1! Click image for larger version.
Name:	tc1 updates.png
    As long as the system reports itself correctly in the 'About' then don't worry about it. On the download site will notice that AE3, 410 Plus, Mini 4K and TC1 all run on the same version number of software.
    Just for my information, what is the exact name of the installer tool you are running? Mine it called 'Download NewTek TriCaster ADV3'.
    Dec 2017
    UK
    35
    Unfortunately I have deleted this already but it was downloaded from the Newtek downloads page.
    Nov 2019
    Birmingham Uk
    10
    Hi all
    I am Having a similar problem might tricastor 410 plus
    I’m on version 7-3-700403 and trying to update to the latest version, but The system is asking for installer ADV3 that it can’t find
    Anyone help with this.
    Kind regards
    Joe
    Nov 2019
    Birmingham Uk
    10
    "[QUOTE=BBZ Studios;1595233]Hi all
    Kind regards
    Joe[/QUOTE
    AMrokestah
    03-16-2020, 10:16 AMkanep
    03-16-2020, 09:44 AMrokestah
    Kanep, that reports correctly Attachment 147082 but when I run updates it comes back with updates for a TC1! Attachment 147083
    03-15-2020, 07:59 PMkanep
    03-15-2020, 01:55 AMrokestah
    Thanks Kanep.
    03-14-2020, 12:42 PMkanep
    03-14-2020, 09:11 AMrokestah
    2/ I also rebuilt my TC-410 from the restore partition and all goes well until I get to AE3 and receive the message in the the attachment Attachment 147079
    Thank you , rolestah... I think my issue could be different to yours, I will always upgraded my Tricaster 410 plus using the correct download ie 410+ . Not TC1 ,
    The last update was fine.
    But then we noticed we had a problem trying to login to YouTube to do a live stream .. we couldn’t login and still can’t.. we had to create a custom set up.
    So on Monday we noticed there was an update for this issue Version 7-3-200515
    We are currently running version 7-3-200408 , but when we try to update to 7-3-200515 it won’t update because the Tricaater is looking for the installer software ADV3 ,but it can’t find it .
    So at the moment we are stuck on version 7-3-200403.
    We believe that 7-3-200515 Will sort out the issue with YouTube. We just tying to understand if this is bug or whether we need to do a complete re-instalment. Thanks!
    Kind regards
    Joe
    Nov 2019
    Birmingham Uk
    10
    Kind regards
    Joe
    Jun 2006
    Chicago, IL
    603
    Yes, the 5-15 AE3 update resolves auto login on YouTube. However, you could still log into YouTube using legacy parameters they supply. We did it for a couple of weeks while this was being resolved and it worked fine.
    Fritz Golman
    Nov 2019
    Birmingham Uk
    10
    Hi Thank you
    So what do I need to get my Tricaater T410 plus back to normal update downloads? AE3
    Kind regards
    Joe
    Quote Originally Posted by BBZ Studios View Post
    Hi Thank you
    Kind regards
    Joe
    I'd contact support.
    Nov 2019
    Birmingham Uk
    10
    Hi Kane
    I managed to get my tricastor 410 plus updated and all is well again, Apart from Premier access I had a free six months trial which I upload recently but now it looks as though I’ve lost that I have tried reactivating Premier access without much success any ideas?
    Kind regards
    Joe
    Contact support and they should be able to get the Premium Access code reset for you.
