Thread: Changing IoR Radially
    Male Modeler ccclarke's Avatar
    Mar 2006
    New England
    134
    Can one of you nodal experts tell me if it's possible to texture a glass cylinder so the Index of Refraction varies from the center to the outer edges? I'm trying to build a GRIN lens using a source light rather than an animated 2D hack to simulate the rays. The center should have an IoR less than the outside diameter. All of the setting I see, (dielectric material node for instance) use a single IoR value, but I'm sure there must be a way to change it from the center of the cylinder outwards.
    Thanks in advance!
    CCC
    Jan 2005
    Colorado Springs
    1,855
    You might be able to use a Gradient on the cylinder's X Coordinate:
ID:	147043 Default Index of Refraction on the Dielectric
ID:	147044 With X-Coordinate Gradient, lower IoR toward edges
    Here's the setup of the attached sample scene / object:
    If you truly want it radially, you could use a Distance Vector between the Object Position and the World Position, zeroing out the appropriate axis to make the distance cylindrical.
    mTp
    P.S. Here's the Radial Gradient IoR setup:
    and the scene / object is attached.
    Attached Files Attached Files
    Last edited by MonroePoteet; 03-12-2020 at 01:15 PM. Reason: Add GRINLens_RadialGradientIoR scene & setup
    Mar 2006
    New England
    134
    Thanks MonroePoteet. You rock!! I'll try this out and see if the light beam raytraces realistically to form a realistic output by taking a coherent light source and shaping it into a focal point. (The size and changing IoR of the GRIN lens allows control of the focal plane.) This is simple to do in Zemax/OpticStudio when designing an optical path, but I'm trying to simulate a working engineering model if it can be done within Lightwave for a larger demo that is more visual than technical.
    Again, many thanks! I really appreciate your help.
    CC
