Results 1 to 9 of 9
Thread: Bullet Dynamics Not Available?
    Oct 2011
    Utah
    490
    I normally use windows and have an imac that I am using temporarily and I cannot use bullet dynamics with my mac lightwave install. I don't think it is just a mac issue but I have scanned the plugin directory and don't know why it is not allowing me to use it. The buttons are greyed out. Any ideas?
Name:	Screen Shot 2020-03-10 at 9.41.49 AM.png
    Frequenter
    Sep 2003
    Munich
    479
    Have you tried the "usual" clearing the config file? And then re-scan the plugin folder
    It looks that way when LW still has the menu branch but canīt find the matching *.p file.
    Oct 2011
    Utah
    490
    I have not tried that yet. I will give that a go when I get back to the imac later today.
    Oct 2011
    Utah
    490
    How do you clear the config files? I have never had to do this before that I can recall.
    May 2003
    Ohio
    1,100
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive on an Amiga 2500 running Wine.
    San Jose, CA
    6,872
    There's more missing than just Bullet, after you reset configs if all that doesn't reappear as it was before, you might also have to re-add the native plugins. Let us know if the config reset alone doesn't fix the issue, and we can help you re-add everything.
    John W.
    May 2003
    Ohio
    1,100
    ...you might also have to re-add the native plugins...
    Indeed, but it's probably more than "might"...it's likely essential. I'd rescan my plugins folder (which will update the configs) before choosing to blow up (reset) the configs. Resetting configs should be a last resort if you've done a lot of customization (without config backups).
    To rescan plugins:
    Hit [Alt F11]... and then scan your plugin directory. The default plugins are in the LW installation folder, under "support->plugins".
    Oct 2011
    Utah
    490
    Deleting configs seemed to fix it. Thank you everyone. I am not a mac user normally but for a game we make I needed to use one so I thought it might be easy to use for lightwave videos as well but mac is testing me lol.
    San Jose, CA
    6,872
    Resetting the configs turns on plugin autoscan, and deleting the extension cache forces an autoscan. That likely explains why the issue disappeared upon config reset, and was why I used "might" instead of "must".
    Why the extension cache can get to the state that it blocks autoscan from picking up valid native plugins is a whole different question, and one I really wish they'd put more effort into figuring out. Nuking the extension cache usually resolves that issue, thankfully.
    Unfortunately, not everyone who "deletes configs" follows those instructions -- many leave the extension cache, perpetuating the problem even though they believe they've "reset the configs" (because they haven't really reset all the configs).
    John W.
