Results 1 to 15 of 19
Thread: Updated DP Text Gen
    May 2006
    France
    4,172
    Updated DP Text Gen
    DP Text Gen has been updated to version 1.5,
    -Fixing loading issue with enveloped parameters.
    -Updating internal MSDFGen to version 1.7.1, fixing several edge issues.
    -Adding a new "Digit" counter Type option beside default "Text" Type,
    Animated countdown:
    comes in several formats, from timecode "hh:mm:ss:ff" to a single integer counter.
    Animated TC:
    Animated justified single counter,
    -A new "Offset/Time" parameter, without envelope will add a single offset in seconds to current time or
    replace it with an enveloped time.
    -Added a separated single countdown preset with a special edition of the DS-Digital TTF font,
    for DP Text Gen texture context only.
    Denis.
    Super Member omichon's Avatar
    Bordeaux, FR
    750
    Awesome ! Thank you very much for this, Denis.
    www.oliviermichon.fr | 3D Animation, Motion Graphics and Broadcast Design.
    May 2006
    France
    4,172
    I did also some experimentations with a node, not released yet,
    each letter/character has an index/ID, which can be handled by the Part Info node from DPKit,
    so each letter may be colored individually, and moved like a part/piece in Part Move node.
    One possible setup,
    The animated result,
    Or this one with a text file,
    Denis.
    May 2006
    France
    4,172
    Another animated time lag,
    Also, showing Instance indexes,
    Denis.
    Murcia, Spain
    3,167
    Thanks very much Denis.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050
    1TB SDD
    32Gb Ram
    LightWave 2020
    Very nice Laptop
    Very nice DPont!  
    May 2006
    France
    4,172
    I updated the texture versions of DP Textgen,
    With "Digit" counter Type, you can add text as "Prefix" or "Suffix",
    for both: check "Prefix" in "Text" field, separate them with the * character.
    I released the nodal versions of DP TextGen,
    for pre and post Lightwave 2018, windows & mac versions,
    including a Character Info node with Index output
    (replacing the Part Info node in my example above)
    Nodal Special inputs:
    -"FgColor" can be applied per letter/character/digit, using the Character Info node
    to get an index per letter item.
    -"Angle" input is a rotation angle applied per letter.
    -"U Move", "V Move","U Scale" and "V Scale" inputs work in Letter UV space.
    Denis.
    Bordeaux, FR
    750
    Cool ! Thank you very much, Denis
    Edit : Link to Node version for Lightwave 2018+ doesn't seem to work at the moment.
    May 2006
    France
    4,172
    Quote Originally Posted by omichon View Post
    ...Link to Node version for Lightwave 2018+ doesn't seem to work at the moment.
    Yes, thanks, misnamed 2018 version, …
    but removed for the moment, I got a crashing issue in 2018 node,
    hope to upload it later.
    Denis.
    May 2006
    France
    4,172
    I fixed the issue in the windows and mac DP TextGenNode 2018,
    downloadable now.
    Denis.
    May 2006
    France
    4,172
    I updated the node versions of DP TextGen, to version 1.7
    -Added a "SubText" index input for picking a subtext in a Text File formated with "*" character.
    each group of line must start and end by a line with only a "*" character.
    -"Char Index" input for replacing current character.
    Animated sample,
    -"Shift Index" for shifting upper case, lower case or digit character (A + 2 = C, a + 2 = c, 1 + 2 = 3),
    doesn't affect other characters.
    Animated qample,
    Denis.
    Mighty Cool !
    May 2006
    France
    4,172
    A simple node setup for various dancing letters effect,
    connect this to the last inputs of DP Textgen node (U/V Move, etc)
    nothing complicated, a Math Sin node for ondulating,
    other nodes just for adjusting the effect.
    A few animation samples (quality is rough draft VPR)
    simple scaling effect,
    pseudo rotating letters (vertical scaling),
    with the Mirror node (from DP Kit, applied after the DP TextGen node),
    multiplying samples with the Average node (Blur Effect node could be used too)
    Denis.
    Very Nice!!
    Magic!   
    May 2006
    France
    4,172
    As a post-process in DP Filter, for a rough text generation,
    I recommend to use Pixel Filter node editor,
    because you can get a nice and fast Anti-Aliasing, even with Adaptive sampling,
    until it is included or added to main buffer or beauty pass.
    For this you need to enable the AA option in the node editor panel,
    just use the ratio of the image as Y Scaling in the node
    and adjust Alignment, Letter Size etc.
    Animated drop text,
    ...Also any Text overlay in Pixel node editor, should be visible in VPR (LW2018+),
    ...but seems that Multithreading in Pixel Filter NE is crashy with VPR,
    so it is limited here, as I can see VPR screen coordinates are strange.
    Denis.
