Results 1 to 10 of 10
Thread: Unreal (2.24.2) Bridge to LW?
    Super Member Kevbarnes's Avatar
    Nov 2006
    Gloucestershire UK
    515
    Just trying to link to Unreal Engine 2.24.2 - but 'LightWaveBridge' is still at 2.23. any update available yet ?
    "one rig to rule them all"
    PC Spec: Intel i7 X980 3.33GHz | 24Gb | ATI FirePro V5800 | W7
    https://vimeo.com/kevbarnes/showreel
    https://littlstar.com/kevbarnes
    https://www.talenthouse.com/kevbarnes
    Is there a particular feature you need from that version? If the answer is no, then i'd recommend against using the latest version.
    Nov 2006
    Gloucestershire UK
    515
    Quote Originally Posted by Ryan Roye View Post
    Hi Ryan
    I was going through your Tutorials and I had already updated Unreal to 4.24.2 before I got your training, assuming latest is best.
    don't think I can back-date to earlier Unreal.
    I assuming I have to wait for LW to update the Bridge.
    Are - hold on, just found I can re-install 4.23.1 - will have a go at that
    Quote Originally Posted by Kevbarnes View Post
    Unlike most other programs, latest in Unreal is usually not best unless it fixes a specific issue you require or adds a critical workflow element that you currently need. You're safe sticking with the version that Lightwave supports, you're not missing out on anything substantial... at least for now. I'm certain periodic Lightwave updates will be done to maintain support for Unreal bridge as needed to take advantage of emerging tech.
    Fortunately, Unreal made it easy to jump between versions using the Epic Games Launcher. See image. You can also click the down arrow next to the "Update" text to set any one of those versions to your default.
    Nov 2006
    Gloucestershire UK
    515
    ok - thanks for that, I just jumped straight in with an update - I'm now installing 4.23 so I should be able to set up with that.
    cheers kev
    San Jose, CA
    6,957
    It's March 2020, UE 4.24 previewed in Nov 2019, was released in Dec 2019, and there's still no LW bridge update for it. The available evidence doesn't support your position. UE 4.25 is in preview already, as well.
    When it comes to "keeping up" with regularly-advancing 3D formats/libraries, the LW devs historically haven't done well -- consider Alembic, or Collada, or even FBX (or OBJ), for that matter.
    John W.
    It's March 2020, 4.24 debuted in Nov 2019, was released in Dec 2019, and there's still no bridge update for UE 4.24. The available evidence doesn't support your position.
    I'm not dancing for you dude, if you don't want to do the research that's your problem.
    ack ack Markc's Avatar
    Feb 2006
    England
    1,537
    Ok I am confused.
    I am installing UE for first time from Epic launcher, the version it shows is 4.22.3.
    But just looked in the pull down and there is also 4.24.3.
    Which version will work with latest LW 2019?
    It’s a big download so don’t want to repeat it.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2020
    (plugins: LWcad 2018, TFD 1427, Syflex 2018, StarPro 2020, ExrTrader 2020, Ubercam 2.0, RR Daz Mocap (not working), DP Light 2020)
    May 2015
    Philippines
    221
    Unreal Engine should have 4.23 available for download. The latest version of Lightwave 3D is compatible with that.
    System:
    i7-8086K / GTX 1080 / 32GB RAM
    Feb 2006
    England
    1,537
    Does that mean 4.22.3 doesn’t work.....?
    Well I gave up.
    Installed 4.22.3 after about an hour.....downloading, installing, verifying, what a palaver.
    Launched from Epic launcher.....stuck at 18% initialising....
    Too much hassle for me...
