Results 1 to 8 of 8
Thread: Bullet and Kinematic object
    Time Traveller Andy Webb's Avatar
    Hertfordshire UK
    2,179
    I have a Bullet cloth sim and the cloth is being blown with a forcefield, the cloth is being held in place with a kinematic null.
    However there needs to be a point when the cloth is blown away.
    So my question is, is there a way to turn the kinematic off at a moment in time?
    Andy Webb
    Intel core i7-3820 3.60GHz
    ASUS PRIME Z370-A motherboard
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    16,751
    Checked, seems there isnīt.
    Maybe with other item bodies.
    perhaps use a parts body, parented to the kinematic object, but it needs to be setup so the kinematic object doesnīt affect the cloth, and then use activate on last key, that way the parts body will still hold the deforming body, but once activated by keyframe, the parts body will drop with the deforming body.
    Not sure though.
    Checked, no that wonīt work.
    No, in this case you need to use a combination of the following:
    Shape Retention: usually "translation and rotation"
    Texture property on Shape Retention: Gradient that uses weight map, with layer opacity being the control which turns the constraint on or off
    The kinematic object method is good for quick setups, but there is no way to my knowledge to make the deforming body break free of it at a specified keyframe. You need to use a weight map method instead.
    Hertfordshire UK
    2,179
    Feature request needed.
    Deactivate envelopes.
    Another feature request that probably won't happen
    Andy Webb
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    16,751
    Quote Originally Posted by Andy Webb View Post
    It Wonīt happen if itīs not asked for.
    Hertfordshire UK
    2,179
    I've now had time to try this in Cloth FX and the effect is better but a similar problem.
    The point set fixes the cloth but how can I choose a frame to release the fix?
    Andy Webb
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    San Jose, CA
    6,879
    This is where Syflex pins come in really handy.
    John W.
