Results 1 to 15 of 18
Thread: Face Expressions Using Control Points?
    Was poking around and found this video by Fabio Annunziata
    He has a facerig that drives morphs instead of using sliders and
    posted a link in the comments showing what he based his setup on...
    That video isn't available anymore on youtube
    Would anyone have any ideas about his setup?
    3D Artist http://www.mike3d.com
    Fine Art Portfolio http://www.macb.ca
    Nov 2003
    jersey
    5,792
    Its just combination shapes... you use null positions to drive morphs either via expressions or nodes. The real trick is in the shapes set that's used.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    May 2012
    Virginia
    530
    Haven't really had the opportunity to set up a face rig.... have used morphs, of course, but would really like to see a full rig like this working just so I could get a better idea of how it works.
    Thanks Rebelhill, when I get serious about rigging I'll be checking out your videos.. impressive stuff!
    Quote Originally Posted by RPSchmidt View Post
    http://rebelhill.net/html/rhfr.html
    Ohio
    1,105
    RH, is this still in development? The last build I received only works in 2018. In 2019, it kicks a licensing error.
    pass:sword OFF's Avatar
    Russia
    1,080
    Here is the scene with the settings for the face animation interface, which the author Luca Burchietti kindly provided me (I hope he will not mind that I posted the scene here):
    Face_CTRL_Export.zip
    Just add a Nodal Displacement modifier (attached to Mitro_v010_head character) from this scene to the scene with your character and replace the morphs with yours.
    Mighty Nice!   
    sidenote; would still recommend you guys take a look at the RH technique.
    Gorden also made a nice setup together with Kvaalen, a custom Expresso plugin, available in this book >
    https://www.amazon.co.uk/gp/offer-li...sr=1-1-catcorr
    Mar 2016
    Oxford, UK
    937
    Gorden also made a nice setup together with Kvaalen, a custom Expresso plugin...
    The Kvaalen site is still up, and still has the face plugin Joytrol to download - would that be the same thing, or similar ?
    http://kvaalen.com/jt/index.html
    similar, not 100% the same...
    more advanced.
    Russia
    1,080
    more advanced.
    What is this? It's not Joytrol, right?
    Nov 2003
    jersey
    5,792
    I'm pretty sure joytrol stopped working (or stopped working properly) quite some time ago in a previous version of LW (somewhere around v9/10 perhaps it was). Either way, it had limitations against setting up your own woth nulls which, done nodally, is very easy and gives great flexibility.
    RHN Nodal Tutorials
    no, as far as i know, JT stopped working in LightWave 8
    this one "Expresso JC" (Expresso JoyControl?) looks to work in LightWave 11.6, from tests.
    i believe "RH Face Rigging" goes much more into detail on non-linear facial animation.
    an important aspect, less covered with other "simpler" setups.
    Nov 2003
    jersey
    5,792
    Not sure what's up there... works ok here on 19.
    Email with your info and I'll see if I can find whats going on.
    RHN Nodal Tutorials
