Thread: Bones On/Off problem
    Near Beaverton, OR
    1,618
    I'm not all that well versed in working with Bones but haven't encountered this problem before. This is in 2019.15.
    I've a character, imported from a FBX file into Layout. I was simply going through, seeing which bones are working correctly, etc. The Eyeball pivots were off so turned Bones Off, reposition the pivots, Turned Bones back ON and now none of the bones are deforming as before turning them off.
    They move or rotate the entire character from their respective pivot instead of deforming. When Bones are turned back ON, that enables the base_bone_transformer which was OFF prior, but disabling that made no difference.
    I'm pretty sure this is just simple OpError, but what am I missing?
    These are using the Neck bone as more visible showing the problem.
    The Big Apexx System:
    64GB DDR4-2666
    Near Beaverton, OR
    1,618
    Wow. Really?
    Dozens of views & no one is even curious enough to check if this is happening with you as well? I don't have any previous versions installed to test. I will next week but hoping someone would at least look sooner.
    64GB DDR4-2666
    Registered User Skywatcher_NT's Avatar
    Nov 2006
    Belgium
    174
    Select all bones. Press CTRL R. Press R. Should 're-skin' the mesh.
    Near Beaverton, OR
    1,618
    Nope. Its not having it.
    Check some older scenes & can toggle Bones on & Off w/o issue.
    64GB DDR4-2666
