Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: How to Soft Body a Tree like This in Lightwave?
  1. #31
    Jan 2005
    Colorado Springs
    1,841
    Same technique, non-photorealistic render, composited "by twos":
    Bullet_Tree_6_InWind_LWEdgerPainter_Composite.MOV
    mTp
  2. #32
    Jan 2005
    Colorado Springs
    1,841
    Here's the scene file for the prior animation, if anyone's interested. A couple of modifications over the prior scene: I added a Bend deformer to have the overall tree sway:
    which uses a Noisy Channel envelope modifier to sway "randomly".
    In addition to the oscillating Rotation, the Leaf instancer includes a random Offset per leaf, separating it from the DP Tree branches:
    Of course, there aren't any "branchlets" or petioles connecting the DP Tree branches to the offset leaves, but that's OK for the non-photorealistic animation.
    The attached scene file had the LWEdgerPainter and Full Resolution Blur plug-ins removed from the Image Processing panel (CTRL-F8) - the LWEdgerPainter is a home-grown plug-in not suitable for publication, but whose non-photorealistic drawing type effect can probably be attained with the Sketch plugin. I also didn't package the Dynamics folder (baked Bullet displacement data) due to forum size restrictions.
    mTp
    Attached Files Attached Files
    Last edited by MonroePoteet; 02-26-2020 at 08:30 AM. Reason: Use correct packaged scene / object ZIP
