Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: LightWave Flip Fluids
    Just curious,
    how do you / would you render your splash/wave animations in LightWave ?
    some notes >
    *some info might be incorrect, mis-leading, i take no resp... and all that jazz...
    May 2003
    Ohio
    1,042
    If this is not limited to accurate physics simulations, there's also this (which could augment the "no wave sim" options):
    https://forums.newtek.com/showthread...or-LW2018-2019
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive on an Amiga 2500 running Wine.
    Feb 2006
    england
    1,359
    Just curious,
    some notes >
    ive actually just been using flip in Blender to get a sim into lightwave, I had a tight time frame so I tried several like Houdini, but quickly saw the learning curve would be quite a bit steeper, the guy who implemented flip was really quick to help with questions etc, even posted several setups along with answers, although you have no wave sim, you can apply the blender ocean modifier to the sim, its incredibly easy to use and very stable, realflow, if you have other software you can get the plugin for considerably less than full version.
    Once OD_Tools shared the importer, I thought that was the no brainer choice, of sorts.
    Fun and stable, it can do as advertised. Octane churns through that beautiful water so nicely. Pun intended.
    Robert Wilson, MA Deaf Ed.
    Indiana Deaf School
    yes, Houdini seems more tricky to set up, i'd also like to know the calculation time difference between Houdini / B FlipFluids / Deep Rising
    the most interesting apps-plugins seem to be >
    Houdini Indie  (320 + 270 each year)
    Blender FlipFluids  (270)
    Deep Rising  (250)
    Lately i think Deep Rising has been coming along >
    Might land on Deep Rising actually... we'll see.
    no, a main focus of physics sims here, thanks tho' an important link and great contribution from DPont.  
    Steam username: Carm3D Carm3D's Avatar
    Earth
    2,332
    I think it's only fair to integrate UP in there. Pro is LW Integration. Con is poor collision detection with deforming geometry as well as promised expansion modules which don't appear to be happening.
    Carm
    Carm3D.com
    vimeo.com/carm3d
    "All war is deception." - Sun Tzu
    Feb 2006
    england
    1,359
    Deep Rising  (250)
    just to point out, Houdini free has the sims, and as far as I know it exports too
    unfortunately it is non-commercial.
    so only applicable for testing.
    yeah, I just think it lacks too many features, no particles or foam, no motion blur, poor collision, +no further development (it seems).
    May 2007
    Belfort, France
    1,877
    OD shelf tools isn't compulsory to export from Houdini to Lightwave, you can do that manually (in sdf VDB or .OBJ sequence, your choice). OD shelf tools simplifies the process, of course.
    You can also export flip fluid from Blender without OD_tools as .OBJ sequences manually. OD tools script will of course simplify greatly the process as it exports all at once, much quicker than from Blender native exporter and creates the lws.
    So your price comparison chart is a bit misleading. On the other hand, you can do so many more things in Houdini that you can export to LW (clouds, smoke, fire, debris, accurate dynamics) that the much higher price tag becomes quite relative if you want to have solutions for other FX than just flip fluids.
    I would add that Flip Fluids for Blender is very easy to learn, but you can't do as much things as you can in Houdini. For instances, waves on a huge ocean isn't that easy in Flip fluids for Blender.
    Edit : in my tests, calculation times are way much higher with flip fluids in Blender than in Houdini. You get what you pay for. Not to say FF for Blender is not good : i use it a lot and will continue to use it. But I'm pretty sure when i have finished to learn Houdini, it will be a no-brainer, especially with regards to speed and flexibility.
    Jun 2014
    Right here
    1,737
    Yes agree. Hurley just disappeared woth no notice or updates for his plugins.
    I have bought Advanced Placement which was never updated to 2018+ and is still very unstable. Waste of money.
    DeepRising seems too expensive for the mediocre results and unintuitive workflow to me.
    I would rather rent Houdini Indie for a year or two.
    However I'm covered with various fluid tools in Blender and Cinema.
    Hopefully NewTek fixed Alembic for the new LW version.
    Thanks for the input on the time, i'm quite curious to what the difference is, twice as slow? might have to run tests down the line.
    part reason why Advanced Placement LW2018 /2019 ain't updated is because of a LightWave bug, it seems.
    https://forums.newtek.com/showthread...=1#post1580697
    nah, nowhere near expensive, but i agree the results could be better. it is coming along tho'
    cool, but it could get more expensive if you are looking at a 10-years span. $2000+
    The good thing is that there's finally some mid-range competition / options.   
    Jun 2014
    Right here
    1,737
    ... part reason why Advanced Placement LW2018 /2019 ain't updated is because of a LightWave bug, it seems...
    Thanks for the info about AP!
    Yes fully agree, rental (Houdini Indie) is more expensive over time - and at the end you have nothing. A reason I don't like rental. However with Houdini I would make an exception - it's price is extremely fair for what you get.
    Base on what I've read about Houdini, if you rented it for this 10 year span, you would end up with a boatload of irreplaceable knowledge about a really difficult program.
    Knowledge can't be said to be "nothing". The knowledge, for me, would be worth the 2k.
    Besides, if one is making money off this field, clients get to pay for our cool tools.
    edit: Marander, it may read like I'm disagreeing. I'm not. Concurring with what you said.
    Indiana Deaf School
    Jun 2014
    Right here
    1,737
    Quote Originally Posted by [email protected] View Post
    Yes, good point - agree, the gained knowledge can be worth alot!
