Thread: Mix Identifier Prefixes on multiview
    Jan 2018
    Winter Park
    412
    Often when doing shows I will have my mix outputs on my multiviewer to see what is going out. These are Identified with Mix 1 [Current Source Name].
    This is great letting you know what is Feeding the mix. Where I run into issue is knowing if Mix 1 is actually set to Program (which is on a given input) or if Mix 1 is set specifically to said input.
    Program is currently showing Input 1
    Mix 1 [Input 1]
    Mix 2 [Input 1]
    The only way I can tell the difference is to move the program bus around and see if it changes or not, or open up the Output configuration and see what is set.
    I think it would be great to see something like:
    Mix 1 [PGRM - Input1] - Configured to show Program which currently is set to input 1
    Mix 2 [Input 1] - Configured to only show Input 1
    This would allow the operator to know at a glance what is currently configured on the Mix outputs from the multiveiw
    19,483
    Mix 1-4 do not usually change dynamically during a show. Generally, they are configured manually, and remain static thereafter. And if memory serves, the Mix outputs can be renamed. As a workaround, why not change the name of Mix 1 (for example) to "Mix1(PGM)", or something similar?
    Jan 2018
    Winter Park
    412
    I had looked at renaming them originally and didnt think you could cause it just opened the output window instead of the normal properties I was looking for. I tried updating the name however can only be 6 chars long compared to normal naming. This is still better than it was before. But I would love to be able to set it to Mix 1 - PGRM vs Mix1-P
    In terms of changing dynamically you are correct, Mix 1 during the show is usually set to program and not changed but name in the multiviewer will always be [name of mix] - [Current input on program]
    Jan 2018
    Winter Park
    412
    Maybe the better way to have worded this is: The mix names have a dynamic adjustment after the Mix name when on the multiview. When the mix is set to Program I would expect the dynamic part to say Program or PRGRM or something to this effect versus the current input on program which is misleading
