Results 1 to 10 of 10
Thread: Subpatch Image Distortion
    icon kid
    May 2006
    New York City, New York
    46
    Is there a way to make an image not change it's shape and size when an object is converted to subpatch? See attached picture. This is the lower part of a stapler. The metal plates (in gray) is an image. When subpatched the image adheres to the spline lines of the subpatch -- not good. I tried selections from the "Subpatch Interpolation" menu (Linear, Subpatch, Linear Corners, Linear Edges, Across discontinuous Edges), but none of those changed anything.
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,584
    Are you using native subpatches, or Catmull-Clark? If using Catmull-Clark, switch over to native subpatches, those work with the UV Subpatch Interpolation.
    Also, I would try to remake your model, and try to keep it to all quads, it will lessen the distortion, and make it easier to add hold edges.
    My Scripts for Lightwave
ID:	146723 need to knife the geometry in top or side view, the more cuts the better it will hold it's shape, and as already stated keep it quadratic and LW subs
    Yep - good advice from all the above. gerry's advice will get this model to do what you desire, its my advice and Kryslin's that a "re-write" is in order. There is a real art to sub-D modeling and poly flow is real important. I rarely model anything in hard polys anymore as Sub-D models give you more detail at close camera views.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Male Modeler ccclarke's Avatar
    Mar 2006
    New England
    134
    Here's a simple, all-quads version of your object. The extra lines, (mentioned above) can be added with the Connect or Knife tools. Use the Edit Edges tool to place the new lines where you want to control the mesh.
Name:	All Quads Version.jpg
    icon kid
    May 2006
    46
    OK. I managed to get the results I wanted by making eight or ten slices (see picture). Very tedious to figure out exactly where to make the cuts so that they could be adjusted to within the necessary ranges, which added 81 polygons to what was 430. I'll take the advice to us all quads for subpatching in the future.
    Yeah that's super sloppy, but works I guess.
    Tim Parsons
    Technical Designer
    San Jose, CA
    6,872
    Quote Originally Posted by icon kid View Post
    I'd be cautious about the mess in the two "uprights", you've got some odd-looking pole-like poly flow going on there, could lead to rendering artifacts. If possible, you want it to look cleaner, more like cclarke's flow.
    John W.
    Sep 2015
    Sweden
    781
    Yep. Cleaner poly flow and everything will be better. You have way more geometry than you need to make that shape using sub patches. You generally want only the edge loops necessary to hold the shape when sub patch modeling, and as few triangles as possible.
    Pessac
    5,161
    In the docs, have a look at Richard Culver's excellent subpatch modelling tutorial. It's old, but it still holds true: https://docs.lightwave3d.com/display...patch+Modeling
    B
    LightWave 3D Trial Edition
