Results 16 to 23 of 23
Thread: Pose Library...
    6,769
    Scripting/programming is a fantastic way to control emotions.
    Never heard it put quite that way, interesting. Of course, the real difficulty is getting access to the REPL...
    A new method for transfering data from external LWS scene files, support for Insert/Backspace in the negative frame range to be able to create additional frames (or remove them) without corrupting the motion/pose Library or the animation in the positive frame range, EXT Transfer can now also transfer the Pose Track data and the Text Tracks from external sources, EXT Transfer is now also able to (optionally) create a MarkerRegion that matches the source MarkerRegion type.
    On a semi-related topic, it's kind of a shame the LWSDK doesn't provide better hooks to override/augment the actual LWO & LWS (really, all) file load/save access mechanisms themselves. Not only would that enable adding proper VCS-type functionality, as well as CMS-type hooks, but would also offer unique capabilities in scenarios like yours (having ability to bind/access various "meta-scene" LWS's, LWS templates, and other files "around" access to the main LWS, as well as potentially even building/assembling the LWS loaded "on the fly"). Alas.
    Still, given what the SDK does provide, that all sounds extremely useful!
    Murcia, Spain
    3,127
    Look forward to it Vincent.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Super Member vncnt's Avatar
    Amsterdam
    1,654
    Uploaded video #1 "Introduction" to https://vimeo.com/393178345
    I have to wait 7 days before I can upload video #2 "Backplate switching" because of their weekly limit.
    Download the latest build from the download section in this page: http://home.kpn.nl/vincentmesman/legato.html The video on Vimeo is embedded in this page.
    Amsterdam
    1,654
    Updated demo content: http://home.kpn.nl/vincentmesman/Legato_demo.zip
    All scenes use the new plugin file format of build 20-FEB-2020.
    IKarm_source.lws has 1 action for the arm, and 2 poses for the hand.
    To apply these markerregions in another scene:
    1 - Open scene IKarm_target.lws
    2 - Press F7 to open Config
    3a - Remove Meshes/Bones/Lights/Cameras from the filter settings
    3b - Verify "Keys", "TextTracks", "Poses" are enabled (being processed), disable "Blocks" and "MarkerRegions"
    3c - Specify your screen dimensions (default: 1920x1080 16:9), then click "Set Layout Now"
    4 - Press F7 again to close Config
    5 - Set current frame to #50
    6 - Verify that the Library file matches the path on your system
    7 - Click the small "E" button to import envelope data of that Library file
    8a - Select 'm' in the 'M','R','m','r','S','T' selector to list available Poses
    8b - Or select "r" in that same markerregion type selector to list available Actions
    9 - Select any of the available Poses or Actions and press 'T' on your keyboard to Transfer the external envelope data to the arm in this scene
    10 - Use the Spline type feature (right side of the interface to define a TCB Spline with T=1.0 to a selected frame range or the current frame for slow-in/out
    Murcia, Spain
    3,127
    Thanks Vincent.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    6,769
    Thanks Vincent.
    Yes, thanks muchly!
    Amsterdam
    1,654
    L2020 update:
    Enhanced backbround color of Library (red), Shot handle start (green), and Shot handle end (blue) for improved visibility.
    Download build 27-FEB-2020 here:
    http://home.kpn.nl/vincentmesman/legato.html#download
    Cool. Alotta work goin into it
    Rob Depew
    Modeler/Animator/Editor
    Web Portfolio
    My Patreon
    YouTube
