Thread: Best Way To Get Rid Of White Noise On Reflection of Logo...
    Nov 2010
    Spain
    24
    Hey guys looking for a little advice and help... been trying to render out my logo with reflections... using a 8K HDRI... I'm using the illumination from the hdri to light the logo... the render looks ok apart from obvious red noise and white spot noise on the reflections of the blue and yellow edging... how can I completely remove these?
    A couple things come to mind. Up your reflection samples, blur your HDRI and/or check the “limit dynamic range” button on the processing tab on the Effects panel. That is of course if you are using LW2018 or 19.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    yes.
    - Up your AA samples
    - Try a Despike of 0.1
