Thread: Recommended Port Settings for Cisco SG300
    Jul 2015
    Kirkland, WA
    124
    I've set my TriCaster's NIC and Cisco Switch port to 1G Full Duplex but am wondering about flow control. The default for the TriCaster is Rx & Tx Enabled and the Cisco switch is set to Flow Control: Disabled
    Any best practices regarding the TriCaster's and Cisco’s switch settings?
    Also, my TriCaster's NIC driver date is 2014. Would you recommend updating the driver to the latest from the MOBO manufacture or Intel?
    Thanks,
    Rob
    Rob Safran
    Share Wisdom Network
    [email protected]
    TriCaster: 460 AE
    TalkShow: VS4000
    Gnural Net CM & LTA
    VSE and LiveText
    Cameras: 2-Sony PMW-X70, Sony PXW-Z150
    Flow Control is recommended to be on. It applies to TCP transmission, depending on the products being connected UDP or TCP transmission for NDI could be used. Even with if off, it probably will not cause problems in the majority of cases.
    Updating the Ethernet drives is allowed, but not required.
    Jul 2015
    Kirkland, WA
    124
    Thanks Kane!
    btw: your private message count is full, so I can't reply to your response.
    Rob Safran
    [email protected]
    TriCaster: 460 AE
    TalkShow: VS4000
    Gnural Net CM & LTA
    VSE and LiveText
    Thanks, I just cleared out my Inbox and Sent items to open up space.
