Thread: Can Modeler Test for Model Correctness?
    SciEngArtist PabloMack's Avatar
    Dec 2007
    Houston, Texas
    356
    In other words, can it test that the model is fully enclosed and there are no surfaces extending into space?
    there is no sanctuary....
    Mar 2004
    Rochester Hills, MI USA
    545
    No, that’s not it’s purpose, but would be a good idea for a plug-in. I just use Cura and go back and forth until it’s clean.
    Bill Carey
    3900X 3.79
    Win10 Pro 64bit
    32gig Ram
    AMD 5700XT 8gb 20.4.2
    LW 2020.02 x64
    Space Navigator
    8,348
    If object is fully closed, it has no edges used in just one polygon. There are only edges with two polygons.
    Merge points, unify polys, delete one and two point polygons,
    and open Edge Statistics window,
    and toggle checkmark in line for "1 Polygons" and ">2 Polygons", if there are any.
    Near Beaverton, OR
    2,034
    I believe the term is Manifold where an objects surface doesn't penetrate itself, but maybe your looking for something else as "correctness" can encompass a number of issues.
    BTW, the newly enhanced Join tool in LWCad can now fix coplanar's problems. Quick too. Shows you where & how many co- points, edges, & polys.
    The Big Apexx System:
    64GB
    17,386
    There is also mesh repair under Detail/polygons/mesh repair...
    With options
    clear stray points.
    clear one point poly.
    clear two point poly.
    cap holes.
    triangulate polys.
    non manifold edges.
    It will automaticly check for possible issues and thus the options not having any issue will be greyed out, but if there is any issue..such as a hole in the mesh, it will highlight that option with a checked mark..before you commit to repair that issue.
    Dec 2007
    Houston, Texas
    356
    Yeah. Basically I am wanting to make sure the object is fully enclosed. Thanks for the info. I hadn't thought of this.
