Thread: Double Box with VideoBackground
    Oct 2015
    Israel
    97
    Would like to understand whats the best way to create a doublebox with a video background.
    I created a buffer with 300 frames into it. playing a loop background video.
    Also - I created a double box VirtualSet.
    Having a Tricaster Mini AE3.
    Whats the best workflow for that?
    Thank you in advanced,
    Tomer
    To do this, you probably aren't going to use a virtual set or at least you would need to setup the virtual set in the following manner.
    Without a virtual set:
    Set the M/E to the 'Default 2 Layer' set.
    Set the B channel to your buffer.
    Then use the A buffer and one of the keyers to place the two boxes on the screen, you can also add borders to these as well.
    With a virtual set double box:
    Your virtual set will need one of layer to be the full screen background as the A or B layer. Load the set, then use a keyer like in the method above to place the additional double box.
    Oct 2015
    Israel
    97
    Kane - you explained it very clear.
    Thank you,
    Tomer
