Thread: Virtual set from Video
    Oct 2015
    Israel
    96
    Would like to get some ideas for the right workflow:
    Planing on a virtual set on a stage with 3 angles.
    Angle 1 - infront of the stage.
    I can see the heads of the audience moving.
    Having a big screen on the stage.
    How can I use this video with a virtual set. keeping it as a video?
    Its more alive when the heads are moving. and the lights on the chair is changing.
    Photoshop is static.
    Should I use buffer or another idea?
    Thank you,
    Tomer
    Aug 2016
    USA
    523
    The main issue is that you only have 2 inputs for the set. A Input and B Input.
    'A' would be the talent and 'B' would be the video if you want. In that case you could couldn't have anything else, like over the shoulder graphics or anything on a screen if you had one on stage.
    One way you could accomplish this would be to have the video of the audience heads in a DDR and key that over your virtual set. You would lose a DDR, but you wouldn't always have to be seeing the heads of the audience. You could keep that for one camera shot.
    I can't think of any show that I've seen when you can always see the audience.
    Oct 2015
    Israel
    96
    Thanks Stream.
    Planning to have lectures in front "as if" in front of an audience. TED-style.
    Will try it with a buffer - to animate the video. (the only limitation is 300 frames).
    Looking for other ideas how to accomplish that...
    Aug 2016
    USA
    523
    Tomer, use a DSK and run it from a DDR
