Results 1 to 15 of 16
Thread: Lightwave scene camera view only show the backgroung. Pespective show the camera.
Name:	Anotação 2019-12-19 102417.jpg
ID:	146457Click image for larger version.
    What is wrong?
    Fernando Rodrigues
    [email protected]
    www.fersoft.com.br
    (AMD 2400-1Gb RAM-160GB HD-ATI 9520-MSI KT6 Delta-Win XP Pro)
    Click that little "target" button in the upper right.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Who I see the objects in Camera view? Show only the background. What can be wrong? Thank You.
    Fernando Rodrigues
    [email protected]
    www.fersoft.com.br
    15,823
    I don´t think what you suggest is something he needs...
    though the question is a bit unclear due to the english, I think He want´s to see the objects in the camera view, but he only see´s the background, despite he is targeting
    Something with a null.
    - - - Updated - - -
    15,823
    Quote Originally Posted by fersoft View Post
    I can not follow your english properly,so guessing here...
    You want the objects to bee seen in camera view right?
    Seems your null may be placed of chart from any object, try targeting a vehicle instead and make sure that works...
    then parent your target null to any vechicle if needed, or adjust the null to be in vicinity of the objects.
    Yeah it could be anything I suppose.
    Tim Parsons
    Technical Designer
    Near Beaverton, OR
    1,542
    I suspect the OP has his bg image set in Compositing panel AND has his Camera Behind the geometry, essentially what Prom is saying. He should check the Top view as to where the cam & focus points actually are. He's not actually looking through Perspective though, just the cam from the attachments. Once he realizes that he should be able to sort it out.
    ack ack Markc's Avatar
    Feb 2006
    England
    1,426
    What is wrong?
    Post a screen shot of your camera and scene editor settings so we can see how it’s set up.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2019 LWCad 2018
    I will try explain more.
    I open a scene from lightwave 11 in lightwave 2019 and after open, the camera do not show the objects.
    The lw2019 is incompatible with scenes in older versions?
    I can do something to solve?
    Thanks.
    Fernando Rodrigues
    [email protected]
    www.fersoft.com.br
    LightWave Engineer Jarno's Avatar
    New Zealand
    609
    I notice that the camera's view frustum isn't being drawn either. Check the field of view setting of the camera. Maybe something went wrong there and it got set to zero.
    ---JvdL---
    Feb 2006
    England
    1,426
    As mentioned in your other thread, any LW scenes from 2015 or older are not compatible with 2018+.
    Try loading the objects manually into a new scene in 2019.
    Near Beaverton, OR
    1,542
    Not exactly. It's just a one way trip.
    Dec 2019
    Algeria
    4
    I don´t think is something he needs...
    Dec 2019
    Algeria
    4
    Quote Originally Posted by Fleurrose View Post
    audacity temp mail origin
    Anyone to answer here?
    Super Member vncnt's Avatar
    Sep 2003
    Amsterdam
    1,625
    You better post the scene if you want answers.
