Thread: Extremely high CPU load with NDI Library
    Jul 2018
    San Diego, CA
    27
    SO this NDI camera control application we're developing appears to cause very high CPU load (50-70%) on relatively new machines with i7-8700 processors in them. We're in the process of diagnosing, but I figured I'd check to see if anyone had experienced the same and if there might be some known common causes.
    Note: This application uses the NDI library strictly for camera control. There are no video streams coming to, from or through it.
    TIA
    Mark
    Aug 2015
    london
    264
    Quote Originally Posted by 090 View Post
    TIA
    Mark
    One issue experienced with older NDI libraries, was if you connected a Source, then it was effectively disconnected - so NDI was technically in receive but sitting waiting to get more data, that could cause a 100% CPU Core deadlock. Particularly happens via routed signals where the routing is interrupted.
    This appears to have been addressed in later NDI releases.
    Jul 2018
    San Diego, CA
    27
    Whoops. Never saw your response. Thank you for the insight. This is NDI SDK 4.1, though.
    Anyone else have any ideas what's happening or how to troubleshoot? We're pretty new to the NDI SDK and we're stumped.
    LightWave Engineer Jarno's Avatar
    New Zealand
    616
    It sounds like you are sending PTZ (or similar) metadata. Are you limiting how often the data is sent? Without a video or audio stream to clock, NDI will send the metadata stream immediately without any waiting. That can cause a high CPU load due to both the application running frantically, and the network being flooded with a torrent of NDI messages.
    ---JvdL---
    Jul 2018
    San Diego, CA
    27
    By "metadata", do you mean commands? There is no data sent to the cameras unless the user has issued a movement command. The load jumps up as soon as the application is started and the cameras are found and remains high until the application is shut down, regardless of whether any movement commands are being sent. Let me know if that's not what you meant.
