Thread: Buffer Speed - Latest release of AE3 on 860
    There seems to be no control of Buffer Playback Speed on the latest release of AE3 is this correct. Or am I missing something?
    Tricaster 860 AE3
    Cameras EX1s and EX3's
    Old Toaster VT5
    Didn't notice that, not sure if this was a oversight or a planned changed (I never used anything but 100% speed myself). I'll put in a report in case it was a oversight.
    There is a way to do this using the macro system.
Name:	Framebuffer Speed.jpg
    The 'index' is the number of your frame buffer (buffer 2 in my example) and the 'speed' can go from 0 to 100 (in my example .5 is twice as fast as normal). A speed of '1' is normal, values less than 1 are faster and values over 1 are slower. A value of 100 will pause playback.
    Thank you Kane will try that. I use the buffer frame for a background element on Ping Pong in a virtual set. To give me the right speed v number of frames with the speed reduce it has the desired effect. Merry Christmas.
    Tricaster 860 AE3
    Old Toaster VT5
