Thread: How to edit surfaces in layout (with example)
    I figured this is information people might want, so i'm providing a sample script with scene file. Modifying plugins and surface data must be performed through a combination of:
    1) Commands which produce a text file with plugin/surface data (Example: lwsdk.command("Surf_LoadText C:\\mytextfile.txt")
    2) Having the script edit (or replace) those text files through parsing
    3) Commands which load a text file onto a target plugin entry or surface (Example: lwsdk.command("Surf_SaveText C:\\mytextfile.txt")
    The RR_PBR_Surface_Setup.py contained within the zip file will look for files containing key words like "Diffuse" or "Metallic" and automatically set up the nodes on the selected surface. It will save a surface file to the same directory the plugin is run from. Note that this plugin works off of the location of the scene file loaded to find the images and assumes a standard folder structure.
    It serves as an example as to how you can avoid having to work in the node editor through scripting. Feel free to pick apart and modify this script to suit your needs.
    RR_PBR_Script_Example.zip
    Murcia, Spain
    3,094
    Thanks very much Ryan.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Neat! 
    note, .py opens in Notepad++
    or open in regular Notepad if you are really-really hardcore.  
    Frequenter
    Munich
    386
    Cool. Thanks for sharing, Ryan! :-)
    ______________
    lorenz
    Registered User dlvphoto's Avatar
    Feb 2018
    Atlanta, GA
    31
    This helps me tremendously in my attempts to write a linker between Quixel Bridge and LW. ***thank you***.
    Jan 2004
    Boston
    432
    Ryan,
    Very cool!
    Is this the same basic idea of the old Surface file from 2015 and previous?
    No. Starting with LW 2018, the SDK for lightwave gained a few key commands that allows deeper access to data:
    - Enables the user to extract, parse, and write information regarding surfaces, including node connections, envelopes, etc. NOTE: These commands operate relative to the currently selected surface (or the first surface is none is selected). You can manipulate the surface selection through python.
    Surf_LoadText "filename" (filename must be in quotes)
    Surf_SaveText "filename"
    - Enables the user to extract, parse, and write information regarding motion modifiers, item shapes, geometry modifiers, etc.
    SaveServerDataByItemID <itemid> <class> <index> <optional_format> "filename"
    LoadServerDataByItemID <itemid> <class> <index> <optional_format> "filename"
    So, essentially you extract a text file which contains all the information about a surface or plugin, make changes to that data, then re-apply it. Granted, this is very similar to just parsing the scene file itself, the major exception to this is the fact that you can inject changes into the scene *without* needing the user to reload the scene entirely.
