Thread: Recording render settings on render tests
    May 2003
    Ohio
    970
    Is there an ideal method to notate the render settings (samples, denoise settings, etc) when creating test renders?
    I may do a dozen test renders saved to files...using a scratch text document (or scrap of paper) to note settings, render time, and the saved filename.
    Is there a plugin/script that can help to automate this? Could these render settings be watermarked as text on the final render buffer? Could they be saved as a text/xml file that gets saved beside the test render image file, with a matching filename?
    Time Traveller Andy Webb's Avatar
    Hertfordshire UK
    2,167
    That would be very useful indeed
    Andy Webb
    Intel core i7-3820 3.60GHz
    ASUS PRIME Z370-A motherboard
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    Jan 2005
    Colorado Springs
    1,823
    Since LW already adds "Maker Note" metadata to the rendered files, you could make up a list of all the render settings you'd find useful and submit an Enhancement Request to allow for an optional "Extended Output File Metadata" (or some such) to include all the desired render settings. Ideally LW would allow you to pick-and-choose the various render settings to include in the Maker Note.
    You can view the current LW-written metadata in the Image Editor (F6):
    mTp
    May 2007
    Belfort, France
    1,854
    If you have OD_tools, you can save your settings as presets in the OD_SceneQuickSetup function.
    May 2003
    Ohio
    970
    I'll still submit a feature request for the expanded metadata but there's a good workaround with OD Tools. I had not considered Quick Scene Setup on existing scenes.
    So with OD Tools, I set my samples, saving a Quick Scene Setup profile with each render test. Then in the render preview window, I click the "metadata" button and enter the Quick Scene Setup profile name as the "user comment".
    When I pick my favorite render test image, I just find the Quick Scene Setup profile name in the metadata.
    Under Render Properties tab, at the top, is a Render Preset dropdown. You can select "Save to Preset Shelf" and build up a library of presets for rendering. It saves the settings that you create from the Render tab and/or the Global Illumination tab.
    May 2003
    Ohio
    970
    Thanks. That's another good option.
    There are so many other settings that are not covered fully in OD Tools Quick Scene Setup or as a native Render Properties preset (ie. samples for individual lights and cameras) that I'll probably still be using a scratchpad. But these two tools mean a lot fewer notes/scribbles.
