Results 1 to 14 of 14
Thread: Old version of lightwave, render output format
    Registered User tonyvdb's Avatar
    Jan 2006
    Edmonton, Alberta, Canada
    238
    Ok so don't laugh but I still have an old version of lightwave V6.0 running and want to know if I can get plugins or do something that will allow me to render to a video format that I can use with today's 1920x1080 HD formats?
    Or what option do I have after the render is done so I can use it in a video?
    SpeedEdit2 v2.6.2
    Dell XPS9700 i7 core Geforce GTX 1610Ti graphics 16gb ram
    ASUS external BluRay burner
    Amiga 4000D VT Flyer in tower
    JVC Digital S BR-D85U
    Sony EVO9850, Panasonic AG7150
    ack ack Markc's Avatar
    1,526
    Sorry to tell you, but 1920x1080 is not today’s standard, try 4k or higher.
    I can’t remember, but doesn’t LW6.0 let you render to 1920x1080?
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2020
    (plugins: LWcad 2018, TFD 1427, Syflex 2018, StarPro 2020, ExrTrader 2020, Ubercam 2.0, RR Daz Mocap (not working), DP Light 2020)
    Jan 2006
    238
    Yes, I can output at that resolution but I don't get an option to output in mov or mpg or other current format. Not even JPEG
    SpeedEdit2 v2.6.2
    1,526
    What formats do you get.
    I don’t have 6.0 installed for well over a decade.
    Jan 2006
    238
    The original RGB formats .flx, .iff, .tga
    SpeedEdit2 v2.6.2
    Jan 2004
    Boston
    469
    Render out a series of stills and covert the stills into MP4 or whatever you need in any modern editing program.
    One small program I like to use when I don't need all the bells and whistles of Adobe Premier is VideoMach.
    http://gromada.com/videomach/
    Jan 2006
    238
    Thank you. That is helpful
    SpeedEdit2 v2.6.2
    8,067
    Quote Originally Posted by tonyvdb View Post
    You should never render to video format directly. If there will be crash, lack of electricity, you will lose the all data and have to start from scratch.
    Render to PNG32/PNG24/OpenEXR/EXR image file format.
    Then merge frames to final video file.
    Ohio
    1,100
    ...Not even JPEG
    I have no memory of LW6 but even LW4 offered JPG. You may want to rescan/reload your plugin folder, in case the JPG and other i/o plugins were somehow excluded in your configuration.
    (However, indeed...render to image files, not video...then smack those image files into a video file with another tool. I believe even ShotCut can do this for free. https://shotcut.org/ )
    Oct 2003
    Orlando, FL
    4,156
    As true today as it was 15 years ago.
    Jan 2006
    238
    Thanks all, I will see what happened to the plugins. Its been a long time since Ive used Lightwave.
    I know i have them on my Amiga but Im guessing they wont work on the PC version.
    SpeedEdit2 v2.6.2
    Pessac
    5,161
    If you'd like to play with vdb objects, like your handle suggests, you'll need to update to at least LightWave 2018 on the other hand...
    B
    LightWave 3D Trial Edition
    Chances are good that you'll find some useful plugins through the Lightwave website; users submit both free and commercial plugins for everyone to use there:
    https://www.lightwave3d.com/assets/plugins/
    I recommend checking it out whenever you find yourself with particular issues that may be solved a bit easier this way.
    Jan 2006
    238
    Thanks all for your help. I was able to find the correct plugins in a folder and I can now save to Jpg and even an AVI file if necessary
    SpeedEdit2 v2.6.2
