Thread: Is a mixed pc and mac renderfarm possible?
    Registered User Dennik's Avatar
    Winston Salem NC
    207
    Someone offered me some used mac blades. My whole setup is with PC. I was wondering if it is possible to mix those two and run render nodes on a mac with a pc.
    Any ideas?
    Mad Doctor pixelinfected's Avatar
    Jan 2004
    Santa Margherita Ligure
    621
    Quote Originally Posted by Dennik View Post
    Any ideas?
    why not?
    the only problem is about external plugin, if avaible for both platform and if cpu are so long different, in past i remember some difference between cpu, but i talk 10-15 years ago, recently i not see special problems. Check if is a good deal : power of cpu against energy consuming vs the use of online renderfarm.
    Danger! Mad Scientist at work
    I'm a mad genius, a mad scientist, someone like dr. jeckill and frankestein with a bit of Bugs Bunny.
    In Lightwave, yes.
    Oct 2003
    Orlando, FL
    4,156
    Quote Originally Posted by pixelinfected View Post
    I think what you are remembering was the difference in Celeron and Pentium chips resulted in different handling of floating point computations that would result in a flicker of renders when assembled. I think someone found a solution in baking out the lights as a work around. But, as you said, this was quite a few years ago. Not sure what current situation is.
    ack ack Markc's Avatar
    Feb 2006
    England
    1,428
    Mac ‘blades’ havn’t been made for a long time.
    The earlier models where PowerPC, so will not work, later models where intel cpu’s.
    Also different models will only support upto a certain version of MacOS, which may not support your version of LW.
    Find out what the spec is, depends what you have and which version of LW your using.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2019 LWCad 2018
