Results 1 to 2 of 2
Thread: Delete key just stopped working
    Mar 2013
    Texas
    3
    Just had a crash on a PC using using Modeler 11.6.3 and now my Delete key no longer works. I have to go to the Edit menu and click Delete manually. Has anyone else experienced this and is there a fix? Thanks.
    May 2003
    Ohio
    1,011
    With a crash, your config files may have become corrupted. An easy way to test this (before deleting your config files...a common method to refresh them) is to log into the computer with a separate user account (which will use separate LW config files). If the delete key works for the other user, you'll know that you'll need to delete the config files for your original user account.
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive on an Amiga 2500 running Wine.
