Thread: Switching sources in M/E
    Nov 2018
    Weslaco
    5
    So I've read there is a way to assign the T Bar transitions to an M/E by pressing the M/E / FTB button. That should allow me to transition within the M/E, but instead it only "zooms in" to whatever is layered in the M/E. For example, I have a graphic overlay with camera input sources. The graphic overlay is to remain on top the whole time. I'd like to transition to different camera sources while on the M/E instead of just cutting to them. When I press the M/E / FTB button, and move the T-Bar, it only zooms into the graphic overlay with the camera input source underneath. I know I'm missing something, but I haven't been able to figure it out. Any help would be appreciated.
    Using Tricaster TC-1
    Jan 2004
    Trenton, NJ
    464
    Wasn't aware of that functionality - do you have a reference to where that was described? Based on your description, I would set the M/E in 'Mix' mode and use it that way with the KEY for the M/E active and the sources you want to transition between in the A/B rows.
    Let me know if I'm not understanding what you are trying to do.
    Thanks,
    John
    John Mahoney
    GNURAL NET, Inc.
    Trenton, NJ 08691
    [email protected]
    http://www.gnuralnet.com
    Gear:
    Gnural Net LiveToAir, TC1, TC1LP, MDS1, TC8000, Cameras: NDIHX-PTZ1, PTZ Optics ZCAM 20x
    USA
    531
    Just playing around and not sure if I'm right, but press both the DSK 1 and 2 buttons on the CS and have the proper M/E pressed in the Delegate row and see if that helps.
    Nov 2018
    Weslaco
    5
    Quote Originally Posted by jmmultex View Post
    Thanks,
    John
    Thanks for your response. I don't know how to set the M/E in "Mix" mode. Maybe that's the issue?
    Nov 2018
    Weslaco
    5
    Thank you for your response. I've tried pressing both buttons and choosing the M/E delegate, but when I try the T-Bar it zooms into the composite image.
    19,544
    Load a transition effect (such as a Fade) into the M/E, rather than a "LiveSet" effect.
    Nov 2018
    Weslaco
    5
    I'll try that! I'm away from the TC1 at the moment, but I'll try that tomorrow. Thank you for your response!
