Results 1 to 13 of 13
Thread: Upgrade - A Few Questions
    Aug 2016
    USA
    554
    We're thinking about upgrading to a TC1 from our 460 AE2 to keep ahead of the Windows 7 end of support.
    Does anyone know if there is still a trade-in path going from a 460 to a TC1?
    Also the pictures that I see of the Small Control Panel look exactly like our 460 Control Panel. Are they the
    exact same thing? Can I use our 460 Control Panel with the TC1?
    Feb 2009
    Tennessee
    192
    Quote Originally Posted by Stream View Post
    I use my control surface form the 460 with the TC-1. I had ro remap some buttons to work like I want but over all very happy to not have to spend another 5K
    Common Gear Used:
    TriCaster: 40, 460, TC 1
    Time Warp TW42
    Cameras: Sony PXWX70, Newtek PTZ / HX
    Cable Solution:Coax HD_SDI & IP
    Newtek Spark HDMI
    Teradek Cube 105
    Chevy City Express Van
    Aug 2016
    USA
    554
    That's what I was hoping.
    Thanks!
    Apr 2008
    Racine
    1,673
    From what I can tell, the current a la carte (no CS) trade in value of a 460 towards a TC1 is $2000, check with your dealer for sure. Might be better off selling for cash since 460 AE2 is still a very nice system! Or keep it and deal with Windows 7. The "end of support" thing is maybe not as bad as it's being made out to be. There are many opinions on that, depends on your situation. I know many school IT people are having fits over it.
    But yes you can definitely use your 460 CS with TC1. Is physically the same board, but some key labels have changed and as TPUC mentioned you can remap the keys using the utility in TriCaster to do so.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Aug 2016
    USA
    554
    Yeah, for $2000 we might keep it and get some small box or use OBS to do the streaming so the 460 isn't directly connected to the internet, only to the network. Right now our T40 is the extra machine, so the 460 would be better, it just would need to be run without the CS until we get another one.
    Dec 2014
    Chicago
    111
    I am curious as to why you wouldn't want your 460 connected to the internet for streaming. I have a 410 and I plan on using it as long as I can. Would there be a problem with streaming after Windows support has ended? Just trying to plan ahead.
    Aug 2016
    USA
    554
    with support of windows 7 ending I don't want to have a possible security hole in our network. Plus for doing live events, other venues IT departments will not let you use a Windows 7 machine once support has ended.
    Sep 2013
    Atlanta
    322
    I am in the same boat as you, and many others. Our TC8000 / AE3 is still chugging along nicely and I see no need to ditch it, but IT sees things differently. I am going to format/partition a new hard drive and tinker with getting W10 to work with our machine. If it doesn't work, I just re-install the original HD and call it a day.
    I will start working on this after Thanksgiving and I'll post back the results.
    Quote Originally Posted by dhodlick View Post
    This will not work. The NewTek Windows version is embedded and customized. You will brick the box and lose all drivers. I do not recommend this.
    & WPS ROCKS!!!
    Sep 2013
    Atlanta
    322
    Quote Originally Posted by Dominicc View Post
    No, I won't. Please re-read what I posted. I am going to completely remove the existing hard drive, and replace it with one that's formatted with W10 and start from scratch. Doing this will most definitely NOT "brick the box". (Fun fact - its exceptionally hard to "brick the box" when it comes to a PC based device....) Worst case is it boots to Windows 10 and is unable to recognize all the NewTek specific stuff. It will, however, recognize the motherboard, processor, gpx card and RAM - none of which are NewTek pieces. Then I will continue to try to get the TC itself back among the living by doing some stuff on my own in regard to the software package, the installer, and W10 itself.
    If it doesn't work, the hard drive will be removed and replaced with the one that was removed. At which point, the device will be in exactly the same state it was in before I swapped the drive and will boot right up as if nothing happened.
    Jun 2012
    Australia
    272
    I reckon you'll have registration issues.
    Sep 2013
    Atlanta
    322
    The TC booted up just fine with a different HD with W10. Went into the drivers folders on the old system drive and copied everything over to the W10 driver's folder, copied all the NewTek stuff from the appropriate folders (including the hidden ones) and I could get the PC to at least see the hardware, but double clicking on the software packages would pop the "Tricaster is not found on this system" (or something like that...)
    Monkeyed around with it for a few hours and threw in the towel for the day. Swapped the original drive back in there and it acts like nothing ever happened.
    Still a lot more to try out, but that's where we sit right now
    Registered User Tri_plaster09's Avatar
    Jul 2009
    England
    17
    Jeff
    Very interesting Jeff, as I've just asked for a quote from a potential supplier for a TC1 and they included the small control surface, of which we already have with our 460. So it is reassuring to know we can save some money if we can still use it again. As already said IT departments are getting twitchy about a Windows 7 machine on the network and so we are having to consider an upgrade. Must say we have been very impressed with our 460, but tech marches on!!
