Results 1 to 2 of 2
Thread: Restart interrupted Facebook stream
    Oct 2018
    San Antonio, TX
    22
    Is it possible to restart the same Facebook streaming session after exiting/restarting a Live Production session?
    For example:
    - I begin a new session in TriCaster and start streaming to Facebook
    - I need to end the session (for whatever reason, usually a technical glitch)
    - After going back into the same TriCaster session, I'd like to restart the same Facebook streaming session, not start a different one (so that the viewer doesn't have to go find the new stream link)
    My setup:
    TriCaster 460
    AE2
    I start Facebook streaming using the built-in Facebook Stream profile
    Thanks,
    Stephen
    May 2004
    Vancouver, WA
    1,546
    I don't think you can with the plugin. The plugin generates a new post each time you get started. If instead you use the RTMPS streaming with a generic custom connection and manually created Facebook post, you might have a small window to resume the stream before Facebook decides you are gone and ends it anyway.
    Kris
    Replay: 3Play 820
    Cameras: Sony NX5
