Results 1 to 11 of 11
Thread: Need a plugin that reads xyz files
    Registered User Dennik's Avatar
    Winston Salem NC
    207
    I need a seemingly easy to make plugin that reads a csv type file like xyz format, with coordinates and color information, and create a 1point poly with it's color value for each entry.
    My problem is no matter what option I tried, I can't load colored pointclouds into modeler as they all come as points only, not 1 point polys. As such they also don't load color information (having no surface).
    Can anyone help me with this?
    http://www2.trueart.pl/?URIType=Dire...ug-Ins/CSV2OBJ
    - - - Updated - - -
    alternatively, convert it to obj.. and load that.. it'll load vertex color info
    Oliver
    OD Tools Purchase Link: http://origamidigital.com/cart
    Vimeo Channel: https://vimeo.com/channels/850417
    Join ODRoot - https://www.odroot.com
    Aug 2016
    a place
    2,013
    just happen to have been doing this this week. try meshlab.
    i had a go with obj, ply, fbx, dae. no luck as the pointcloud may have vert data but it has no material.
    meshlab will do most formats though, if you want xyz it csv
    will give it another go as i assume oliver is correct. i just converted pointcloud to single point polys and ran a gradient through it. perhaps i should have tried vert cols at that point.
    Where can I get a sample file?
    Color can be loaded into vertex color map…
    I attached a test script, but I don't know Python well.
    Test.zip
    Winston Salem NC
    207
    test with color2.zip
    Hey thanks for the help.
    Here is a sample .xyz file.
    It has 3 columns for the coordinates and 3 columns I assume with the same rgb value repeated.
    The color values are too large. I divided them into 255.
    Test2.zip
    Winston Salem NC
    207
    It worked! Thanks a bunch my friend, I owe you big time!
    Thanks. I also got a useful experience.
    Winston Salem NC
    207
    One thing I noticed though, my models come in flipped on the x axis. Is it the same on your end?
    edit: Sorry you probably don't have a way to test for this. Here is a pointcloud of a sign attached. It reads backwards when imported.sign.zip
    I have a mirror effect too. Coordinates are loaded correctly, but you can add a "minus".
    pt = [-float(row[0]), float(row[1]), float(row[2])]
    or
    pt = [float(row[0]), -float(row[1]), float(row[2])]
    or
    pt = [float(row[0]), float(row[1]), -float(row[2])]
    San Jose, CA
    6,723
    Generally better to implement a double/float scale/direction dummy scalar as per-term multiplier in the path. That way, if you need to flip an axis, or rescale one or more on input, it's just a matter of changing the values of those scale/direction scalars on the appropriate axis. Doing so also makes it easy to implement UI "switches" to flip or rescale axes' values dynamically as needed.
    John W.
