Thread: NDI Adobe plugin and After effect with no alpha
    Thomas TV2
    May 2011
    copenhagen
    92
    Hi
    The Ndi plugin works with alpha from Adobe Premiere, but I cant seam to get it working from After effect. Only with a background color.
    Is it still not possible? I read in an old post that After effect do not support it. Only Premiere.
    Thomas
    TC 8000 AE2
    Tricaster 8000 AE2
    There are two plug-ins.
    'NewTek_NDI_Transmit.prm' and 'NewTek_NDI_AfterEffects.aex' (on Windows)
    The 'prm' plug-in works in Premiere and After Effects, because of how After Effects handles alpha channel it doesn't get passed using the 'prm' plug-in, but Premiere does.
    The 'aex' plug-in works on in After Effects only and supports alpha. What I just noticed is that it appears that an Adobe update appears to make the 'prm' plug-in take priority over the 'aex' one. If I remove 'prm' plug-in then the 'aex' one kicks in and alpha appears.
    This all used to work previously, but it appears that an Adobe updates have changed it. I'll put in a bug report to see what might be done.
    Thomas TV2
    May 2011
    copenhagen
    92
    Hi Kane and thanks for a quick answer
    I will then try, with your hack, on a windowsPC then. I have only tried on a Mac :-)
    Thomas
    Tricaster 8000 AE2
    As an update, the 'aex' plug-in has been deprecated. All Adobe plug-in support is now handled by the 'prm' plug-in.
