Results 1 to 9 of 9
Thread: Need help to open a modeler file after fatal crash error
    Aug 2010
    belgium
    14
    During a modeling session , a fatal error occurs and the program crashes. I didn't realized that I've clicked on "send no report" because the modeler program crashes often but without any consequence because I make regular save of my session. But this time, the source itself is no more readable by the modeler and it can not load anymore. Because this is a two weeks work, I wonder if anybody has an idea how to get this source available again?
    Male Modeler ccclarke's Avatar
    Mar 2006
    New England
    120
    This advice is likely too late if the LWO file is hopelessly corrupted, but ALWAYS save using revision numbers when you're modeling on a deadline (Shift/S). You may have 500 in-progress copies of an object during the course of a build, but in your case, you could have gone back to the last saved revision, losing a much smaller timeframe of work. When the model is complete, keep only the last revision and create a back-up stored elsewhere.
    The majority of us have learned this the hard way. I hope you're able to resurrect your old file in the meantime.
    Good luck,
    CC
    Ohio
    967
    This is all automated but you need to enable it.
    From the docs...
    "When Layout or Modeler are running, you can set LightWave to auto-save objects and scenes in your Preferences dialog. On the General tab go down the near the bottom where you will see two dropdown menus, one for auto-saving Objects, the other for Scenes. In Modeler, you can just choose to auto-save Objects in the General Options panel."
    [https://docs.lightwave3d.com/lw2019/...import-export]
    There are also third party tools to help (I have not tested these lately in 2019).
    http://www.blytools.com/incsave.html
    https://mentalfish.com/2009/12/incremental-save/
    Registered User Kaptive's Avatar
    Jan 2006
    UK
    764
    There are some model translation programs out there that might just salvage something, like accutrans. Chances are slim, but if you want to exhaust options, it is one of them. It might also depend on which version of Lightwave you're using.
    Also, have you checked your lwhub folder? There may be a recent version in there? Normally C:\Users\Youraccount\AppData\Local\Temp\lwhub
    Not sure the full reason for this folder, perhaps as a hub interchange. So if you have passed the object through the hub to layout, you might still have that version.
    That's all I have I'm afraid. But try the hub first and see.
    6,686
    Another possibility, if you're storing objects on the boot drive, and SystemProtection is running, it might have copied a prior version of the file as well. Check the file info.
    Pessac
    5,116
    Same goes for keeping content in Dropbox - the file history on there has saved my skin on several occasions...
    B
    LightWave 3D Trial Edition
    Aug 2010
    belgium
    14
    thank you everybody, it seems that I've a previous version safety placed in my dropbox a couple of days ago, I started repairing the design to get it in final stage but I switch back to the 2018.0.7 and abandon the 2019.1.4 which crashes too often.
    Quote Originally Posted by Kaptive View Post
    Yes it's possible it might load into another program like Accutrans. I would agree this might be worth a shot.
    One thing I've found is that when working in Modeler, if I get a crash report window, before clicking on that I hit the save object button, then make my choice in the crash requester.
    Rob Depew
    Modeler/Animator/Editor
    Web Portfolio
    My Patreon
    YouTube
