Results 16 to 30 of 35
Thread: Lightwave 2019.1.4 - CRASH, horrible
  1. #16
    yes it is a Mac thing and it usually happens when you hold down shift( as in old style, as in no longer necessary but you still do it out of habit) while multi selecting layers and only when selecting a lower layer first followed by one above it, thing is when it crashes it's instantaneous and does not generate crash report, and is also well known and has plagued previous builds of 19x series
  2. #17
    Time Traveller Andy Webb's Avatar
    Hertfordshire UK
    2,169
    Quote Originally Posted by gerry_g View Post
    I get this on a PC too.
    Reported it but NT cannot reproduce it
    Andy Webb
    Intel core i7-3820 3.60GHz
    ASUS PRIME Z370-A motherboard
    GeForce GTX 660
    32 Gb RAM
    Windows 10
  3. #18
    Jan 2005
    Colorado Springs
    1,827
    I reproduced this problem four times in a row using the following steps under LW2019.1.4 on Windows 7:
    1. Invoke Modeler fresh with the Layers panel already up (i.e. F7 prior to exit last time)
    2. Using the numeric panel defaults (i.e. press "n", then RETURN twice), create a Box in Layer 1
    3. Ball in Layer2 (again, numeric panel defaults for all the following)
    4. Disc in Layer 3
    5. Cone in Layer 4
    6. Capsule in Layer 5
    7. Toroid in Layer 6
    8. Press F7 twice to drop and invoke the Layers panel
    9. Expand the layers under "unnamed"
    10. Holding down SHIFT, select Layer 1 as Foreground, Layer 2 as Background
    11. Modeler crashes
    I've attached the TXT file from DebugDiag.
    Good luck!
    mTp
    P.S. reproduced a fifth time following my own instructions above!
  4. #19
    Aug 2017
    Slo
    81
    There is also a video;
    http://ge.tt/26SfQvz2
    2019.1.4 crashes at the end. I can crash modeler 10x faster on mac than win7.
  5. #20
    May 2003
    Ohio
    1,011
    Thanks mTp. I can now recreate this issue on Win7/2019.1.4 with a shorter version of mTp's example...
    1. create a Box in Layer 1
    2. Ball in Layer2
    3. Press F7 to show Layers panel (if not already visible)
    4. Expand the layers under "unnamed"
    5. Holding down SHIFT, select Layer 1 as Foreground, Layer 2 as Background
    6. Modeler crashes
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive on an Amiga 2500 running Wine.
  6. #21
    Aug 2017
    Slo
    81
    2. Ball in Layer2
    6. Modeler crashes
    Your recipe does not crash my LW not on mac neither on win7. At least in my case it is much more complicated than that.
  7. #22
    Oct 2008
    Czech Rep.
    68
    Yeah !!
    LightWave 3DŪ 2019.1.5 Changes
    Bumped product version to 2019.1.5.
    Bumped build number to 3134.
    LB-5860 Modeler crashes when you shift click on one of the background layer spaces under the “b” next to a layer
    LWB-5356 Modeler Crashes when selecting layers from the layer panel
    LWB-5498 Selected layers from the layer bank are not syncing with Layers panel
  8. #23
    Yep that LWB-5356 bug was nasty and weird, I'm glad it's fixed in 2019.1.5 patch. Modeler lot more stable now.
    RAM-Studio
    WS - Dual Xeon E5-2698v4/128GB/Win10x64/4xRTX 2080Ti
  9. #24
    ack ack Markc's Avatar
    Feb 2006
    England
    1,428
    That’s weird, there is normally a thread in the forums announcing a new build.
    Come on chuck.....
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2019 LWCad 2018
  10. #25
    Come on chuck.....
    From what I've heard I think Chuck has retired and is no longer working for Newtek.
  11. #26
    Murcia, Spain
    3,100
    Yeah Chuck has retired and good luck to him.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  12. #27
    15,873
    Come on chuck.....
    Bad left over to the person that will take his duties I would say..and on the brink while releasing an update.
    Someone really needs take over that and immediately notify the release in the forums...how do they suspect people would find out, invest or download, itīs not even on the Lightwave3d page either, it is however..on the Lightwave3D, blog...so the question is where they should update news like that, seems odd that you update one page and not all of them at once.
  13. #28
    Aug 2016
    a place
    2,015
    it's NT, cut them some slack :P
  14. #29
    Pessac
    5,123
    The news is also on the website - https://blog.lightwave3d.com/2020/01...available-now/ and Twitter, and Facebook (I believe)...
    B
    LightWave 3D Trial Edition
  15. #30
    15,873
    B
    Yes I know...but I already said it was on the Lightwave3d Blog on my post 27, so you do not have to enlighten twice cudos though for putting a link to it
    Facebook I didnīt know, donīt have a facebook account
    But you know..since you seem to be aware of it now..still missing...
    https://forums.newtek.com/forumdispl...-Announcements
    A lot of people outside of facebook and not regulary visiting the blog and not able to follow a completly off topic threat with this news embedded, will loose out on the fuzz about the release.
    Obnoxius Mike ..signing off.
