Results 1 to 15 of 17
Thread: Lightwave getting odd results with a normal map from Gaea
    London, UK
    5,603
    Hello All,
    I've been having a lot of fun with the Gaea terrain tool, exporting displacement maps and textures for rendering in Lightwave.
    I've just started trying the Normal Map build from Gaea, but I'm getting odd results.
    To be specific, I'm getting bright areas on some cliffs, acting like they've received a serious boost in diffuse.
    On examining the map, it has some green areas which look to be on the cliffs, whereas I normally expect the colours to be dominated with purple, and a bit of red and blue.
    I attach a smaller version of the map.
    Is this some flavour of Normal map that LW doesn't like?
    (The original is 8k x 8k, PNG format, 16 bits per colour channel).
    Any ideas on how to work around this?
    Maybe editing the map to remove the green, or perhaps to generate a new one from a 16 bit bump map?
    Any software solution needs to handle 16 bit channels and BIG images.
    Thanks in advance for any suggestions,
    Nick
    PS - I'm still mainly using Lw 11.6
Name:	Micro Erosion Normal Map.jpg
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,529
    Using the map you provided, in LW2015 (earliest version I still have installed), I didn't see the issue you described.
    However, doesn't mean it doesn't exist - mainly because jpegs are 8 bit per channel images. Maybe the solution lies into using an image format that use floating point data, like .exr?
    My Scripts for Lightwave
    London, UK
    5,603
    Could be...
    But as I said, I don't normally see the green, so I think there's something else going on with noirmal map flavours.
    Thanks for the suggestion,
    Nick
    hi, looks to be a World space normal map, (or Object space) rather than Tangent space normal map...
    https://gamedev.stackexchange.com/qu...or-normal-maps
    London, UK
    5,603
    Ah, thanks for that.
    And judging by Google, there's a DP kit node to handle the conversion!
    May 2006
    France
    4,070
    I don't know the original displaced terrain,
    but looks like a correct normal map in tangent space,
    You may be surprised by red or green color in it,
    this is because the relief is heavy,
    so the normal of a flat surface is heavily perturbed,
    also commonly it is of course better to displace
    the flat surface with a height map.
    Denis.
    Wow, never thought that would've been Tangent.
    London, UK
    5,603
    Hi Denis, and thanks for the response. You know more about this stuff than me.
    However in this case I'm not convinced - I think the "bad" normal map is close enough to have a normal map like effect.
    I attach two VPR views of the scene, the only difference is that normals are off in one case,
    While it definitely adds roughness, there are the weird bright patches on the cliff face.
    So I suspect that the others are correct, and it's a different type of normal map from what Lightwave is expecting.
    Nick
    not sure, it is either an extreme normal map (where a displacement map would provide a much better result)
    or, like stated in post #4, a World space normal map, (or Object space) rather than Tangent space normal map.
    do check / ask over at the Gaea forum.
    May 2006
    France
    4,070
    Quote Originally Posted by starbase1 View Post
    ...While it definitely adds roughness, there are the weird bright patches on the cliff face.
    So I suspect that the others are correct, and it's a different type of normal map from what Lightwave is expecting...
    When you have different type of Normal map, like different space
    of axis inversion you get garbage, not the case in my test,
    but you may have other kinds of error in the mapping itself,
    don't know how you applied it in Lightwave.
    Denis.
    May 2006
    France
    4,070
    Wanted also to verify if the faked relief above was convincing (without knowing the original)
    not a great resolution but I'm able to get a rough height map,
    and a displaced mesh object;
    Edit: Normal to Height done with AwesomeBump application
    Denis.
    London, UK
    5,603
    Interesting! That looks like a negative of the actual displacement map!
    London, UK
    5,603
    Well, the way I am doing this is a have a 4k x 4k EXR displacement map. I have this producing about as many polygons as my 32Gb memory can hold.
    So my plan is to try adding a higher resolution normal map, (currently trying 8k x 8k), to get an extra level of detail.
    May 2006
    France
    4,070
    So in this case Gaea seems to not have the same Y axis than LW,
    this can be adjusted in LW, try "invert Y" in the normal map node.
    Denis.
