Results 1 to 9 of 9
Thread: How to use downloaded animations on my character
    I am trying to figure out how to download an animation and apply it to my character mesh (for example using MOCAP files and the like)
    In my research on the topic I run into the use of NevronMotion as one method but that doesn't appear in the recent version of Lightwave that I can see. I've seen references to RHiggit as well.
    For example I have downloaded a simple motion from Turbosquid cheerleader dancer 19
    https://www.turbosquid.com/FullPrevi....cfm/ID/694872
    It has an FBX file and a BVH
    I can import the animation easy enough but I can't seem to figure how to retarget it to my character (doing it with some stock character would also be helpful)
    I've looked for tutorials and information in the manual but I can't seem to find anything that gets me going in the right direction.
    I'd appreciate any and all suggestions.
    thanks!
    ack ack Markc's Avatar
    1,418
    You probably need Ryan Royes mocap plugin.
    I have used it with Daz characters, and works very well.
    Thanks for the suggestion markc I did a search for "Ryan Royes mocap plugin" and came up with rrtools. Maybe that's the plugin you are referring to?
    I am trying to figure out a method in LW without a purchase plugin that may do it if possible.
    Greenlaw wrote in a thread a few year's back
    "FBX does not support IK and scripted rig features because that tends to be program specific. It should preserve all nulls/locaters and all bones though. You'll have to add any special controls, like IK, in your animation program. This is why many LightWave animators use Merge Only Motion Envelopes when transferring animation from another program--this way they can use motions created elsewhere (like mocap, for example,) and apply it directly to a rig specifically setup for LightWave"
    https://forums.newtek.com/showthread...30-FBX-Imports
    It is the "merge only motion envelopes" idea I have been pursuing at the moment.
    I can "load items from scene" and select the FBX I downloaded while checking off "merge only motion envelopes" in the second requestor and I will get two objects with a bone hierarchy that demonstrates the motion from the downloaded FBX. This is in Layout.
    It is the next step that I can't seem to figure out. I can't take that moving bone structure and make it affect my Mesh. I've tried adding the Genoma MOCAP rig to my mesh but I can't get that animated motion in the FBX to change my mesh.
    In short, I'm trying to figure out the part in Greenlaw's sentence "...and apply it directly to a rig specifically setup for LightWave" How does one "apply" it (and what would a "rig specifically set up" look like.
    I hope the above makes some sense
    many ways... One >
    Nov 2003
    jersey
    5,774
    Quote Originally Posted by James Moore View Post
    Thus...
    http://rebelhill.net/html/lwandfbx.html
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Erikals,
    Thanks for that tutorial. I'll give IK boost a try.
    RebelHill,
    Thanks for that link but I'm a little confused by what I found there. The details and the 5 parts contain no links and just a text summary. What is that referring to? Where do I find these details?
    1,418
    James this is the plugin I was referring.
    https://www.liberty3d.com/store/tool...mocap-utility/
    Thanks for the suggestions! Here is what I came up with for this years cartoon.
    https://asphaltpotato.com/
    Aug 2014
    South Bend, Indiana
    413
    ^^ Can vouch for this, works beautifully. ^^
    Couldn't recommend rhiggit any more also.
    Never used RR's but i'm sure its great too.
