Thread: Dumb Question Regarding Limited Region...
    Aug 2008
    Largo Florida
    23
    I was experimenting with limited region with one of the scene cameras (lw2018) and it worked ok.
    Trouble was I couldn't adjust the frame, make it go away, shut off or much of anything else.
    It kind of just took over?
    How do you (simply) return to a normal full camera viewport?
    Thanks!
    Hi, i assume you activated the camera and pressed L multiple times ?
    Near Beaverton, OR
    1,522
    You can't be in VPR mode initiaaly. Use any of the other modess, set your region with the handles, then use Ctrl-F9 to toggle in and out of VPR.
    England
    5,900
    Or set your VPR to overlay mode, and then you can see your handles in VPR as well as Opengl.
    But, yeah... Ctrl F9 is your best friend to toggle VPR on or off.
    Desk Work:
    Desk Home:
    You can be in VPR mode when you activate Limited Region. You just have to make sure that OpenGL Overlay is activated or you won't see the region box.
    Near Beaverton, OR
    1,522
    Quote Originally Posted by Axis3d View Post
    Ah, good to know. The Overlay is a bit new & usually have it off. I'm also limping along on a laptop with a fraction of my accustomed to resources. VPR gets very unhappy with MoBlur enabled.
