Thread: render LW
    Mar 2005
    swizzerland
    10
    render LW
    Good morning all
    I'm rendering with the LW2015 rendering engine, an environmental texture. There are many white spots that appear in the picture. How do I remove them? is there a tab to adjust? Thank you for your answers
    JCEClick image for larger version.
    Registered User Schwyhart's Avatar
    Mar 2013
    Tulsa OK
    451
    It's been quite some time since I've used v2015, but look at your camera samples. It probably needs increased.
    Mac Pro
    3.5GHz 6-core with 12MB of L3 cache
    32GB (4x8GB) of 1866MHz DDR3 ECC
    1TB PCIe-based SSD
    Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM each
    Mar 2004
    Derbyshire, UK
    3,143
    Hi JCE - in Layout go to your Render Globals panel, and choose the Render tab. In there, near the bottom, you need to tick on Limit Dynamic Range. That might sort it
    Mar 2005
    swizzerland
    10
    THANK YOU, it's all good with Dynamic Limit
    Registered User 3dhotshot's Avatar
    Mar 2009
    Durban
    299
    Hi there, what light are you using ? drop your scene file here if you like will sort it for ya if you havent yet worked it out ...........
    Mar 2005
    swizzerland
    10
    Hello 3dhotshot, thank you for your return, the problem is solved with Dynymic limit ;-)
    Male Modeler ccclarke's Avatar
    Mar 2006
    New England
    121
    In 2015, Limit Dynamic Range can be enabled in two places:
    1. Render Globals / Render Tab
    2. Windows / Image Processing Tab - This panel allows for precise adjustment of the Dynamic Range Limits settings over the default of 1.0 when #1 is used. In-depth info is on page 2250 of the 2015 documentation.
    CCC
