Results 1 to 8 of 8
Thread: Liquid Particles?
    Aug 2019
    Carbondale, IL
    3
    Liquid Particles?
    I'm in need of help as I have seem to be working in circles. I'm working on a project and I'm attempting to get a look with particles that is similar to water coming out of a pressurized spray. Possibly similar to a house spray painter. Starts out of a nozzle that sprays out and in a line type of spray. So primarily moving away via the x and z axis and very little on the y. Is this effect possible in Lightwave without purchasing a $100+ plugin?
    Thank you all in advance!
    Todd
    San Jose, CA
    6,614
    Well, asking the obvious first, have you tried (with particleFx) adjusting the initial X and Z velocities (and variations) for the particles to give the kind of spray "spread" you're seeking?
    What kind of specific issues are you having with shaping the spray/spread of the particles over time?
    Or are you just asking if it's even feasible? If so, the answer is yes, it's feasible, though if you're looking to have the sprayed particles behave like water when hitting surfaces, etc. then a lot of the feasibility will depend on how detailed and accurate you need the results to appear. ParticleFx and Hypervoxels will definitely get you close, though.
    If you're just starting with PFX and HVs, this is a decent starting point (search "lightwave particles hypervoxels" on YouTube for more):
    William Vaughn - Rain Splash Tutorial
    John W.
    LW2015.3UB/2019.1.4 on MacPro(12C/24T/10.13.6),32GB RAM, NV 980ti
    Apr 2016
    Global
    37
    If you're feeling adventurous, there's always Blender. People have had a lot of success importing into Lightwave.
    Even if you're not interested in purchasing a plugin, you should give the Deep Rising FX demo a try. The results may be satisfactory (for free).
    For complex simulations though, nothing beats a dedicated solution in my opinion.
    Jan 2005
    Colorado Springs
    1,809
    Of course, it depends on the effect you're trying to achieve, but simply having a stream of "paint" come from a shaped nozzle to cover an object is feasible with just ParticleFX. A quick LW 2015 sample scene attached (you didn't indicate what version of LW):
ID:	146230 Click image for larger version.
ID:	146232 Click image for larger version.
    ParticleFX_Spraypaint_StickyCollision.mov MOV File
    I don't have time for a full writeup-up, but the nozzle is a box sized (1,0.1,0.1) to get a wide spray pattern:
    The Hypervoxels are stretched in Velocity which cause them to be stretched in the "spray" but not so when they stop on the Wall. The wall is set up as a Sticky Collision object:
    The size of the HVs is ramped up with a Particle Speed Gradient to make them spread out on the wall when they stop, and the HV Density also has a Particle Speed Gradient to may the spray less dense but the painted wall more so:
    Good luck!
    mTp
    Attached Files Attached Files
    Male Modeler ccclarke's Avatar
    Mar 2006
    New England
    120
    Thanks so much for posting this! I'm working on a project where a derivative of this technique could be very helpful. It's always interesting to see how other artists workflows apply a particular technique in an innovative way.
    Cheers!
    CC
    pretty cool mTp  
    Jan 2005
    Colorado Springs
    1,809
    Thanks! Hope it helps!
    BTW, if a wide Emitter isn't desirable, the wide horizontal spray pattern can also be attained using a small square Emitter and oscillating the Emitter in Heading and setting the Etc=>Parent Motion to 0%. For example:
    mTp
    Mar 2006
    New England
    120
    Nice to have another option in my back pocket. Thanks again!
    CC
