Results 1 to 15 of 18
Thread: LW Layout random scatter objects
    Mar 2018
    Denmark
    41
    This may sound really noob. I loaded in an object containing over 100 layers (debris pieces) and I'd like to randomly scatter them all along the ground. Is there a quick way to add noise to translation or something similar while having all the objects selected?
    Cheers
    Sep 2015
    Sweden
    647
    Can you just use dynamics?
    Near Beaverton, OR
    1,524
    I know there's a way using OD Tools, but Vimeo's search function is so infuriatingly that is basically useless & I can't recall the name. Think it was in the 2015 0r 2018 release. Maybe Oliver or someone who's used it will see your topic & chime in.
    Natively though, using the Bullet tools dynamics as mentioned might be your best option.
    15,596
    Yes, you can use bullet and just select all layers, make them rigid bodies, and hit play and let it fall to the ground, maybe add additional force to scatter it.
    I did som stone placement by "pouring or dropping rock boulders from one single layer (in that case use parts and not rigid bodies)
    You do need to freeze the ground or terrain in order for bullet to recognize the surface interaction properly though, if you have dense displacement, you would need to freeze it, you do not necessarely need to freeze it to itīs highest level, you could freeze it by using saved transform and lower the subpatch so you got a lower "dummy" terrain to serve as interaction..while maintaining the original displacement for the visual look in the end.
    you could also disperse the debri by using collsion or distrubution objects so the falling debris is directed in to various places with the help of this collision object.
    Mar 2018
    Denmark
    41
    Thanks guys. I was thinking about using dynamics to drop them down, but they all load in with the same 0.0.0 origin/pivot location effectively being inside each other from the start, and I imagine using dynamics they already have to be distributed around to some degree before it works as intended. Yes, I could move all 100 objects around manually to begin with, but I may be in a similar situation next time I wanna load up a collection of debris and it seems like a clunky way to work. Maybe there's a plugin like the Jitter in modeler, only for objects in Layout? I'm on 2015.
    15,596
    Quote Originally Posted by GimbalLock View Post
    There is a way kind of..you explode the layers, but first you need to flatten layers in modeler.
    If you can load the object in to modeler, use flatten layers, then go to menu/edit menu and search for explode parts, drag that command to your liking and use that to create a morph, it will explode all none connected segments to a morph, you can then apply that morph to the base by going to map apply morph.
    Now you will have all your layers in exploded in one layer, so you can either use that as a parts object for bullet, or use connected to layers to send them to seperate layers again and use that with bullet as rigid bodies.
    This also assumes each individual debri layers are completely welded and connected by themself.
    With this explode tool, you can set explode radius, explode randomness, explode morph name, and random seed.
    But as mentioned, you do not want it to be a morph, thus you need to apply the morph to the base.
    Sep 2015
    Sweden
    647
    This will only work if each part is contiguous. You can try moving one object to the side. Say 20 meters or so and then selecting all objects and choosing “distribute along all axes” and it should put them all in a neat little row. Once they are separated you can use dynamics or a procedural in nodal motion to make them irregular.
    Oh. 2015. Skip nodal motion. It is a pain prior to 2018 for lots of objects. Distribute then dynamics I think. Is distribute in 2015?
    15,596
    Thereīs also a more complex node way, but it means you still have to flatten layers, then send to layout, and use part move, then save fbx and load as seperate layers again.
    Jan 2005
    Colorado Springs
    1,823
    I don't know if it will suit your needs, but you could use Surface type Instancing on the Ground object. A quick sample scene using just basic geometric primitives in each layer is attached.
    The set up is a little time-consuming with 100 layers but is straightforward.
    Select the Ground object, use the Object Properties=>Instancer tab to add an Instancer. You then need to add all the Layers to the Instancer, but I don't think there's an easy way to add them all at once. What I did for the sample scene was select Layer 1 with the Instancer panel open, then use the Edit=>Add From Layout pulldown to add it to the Instancer. Press down arrow to select Layer 2, Add From Layout. And so forth for all 100 layers!
    In the Instancer panel, you can then select all the instanced Objects by selecting the first one, holding SHIFT down and selecting the last one. Set the Instancer type to Surface, set the visibility (eyeball column) to Textured, and then choose (for example) 400 instances.
    I then set the Rotation of instances to be Random, with a minimum H,P,B of (0,0,0) and a maximum H,P,B of (360,180,90).
    mTp
    P.S. if you don't want homogeneous placement across the surface, you can use modifier Textures on the Weight of the instances. The Weight determines where the instances will be placed, and you could, for example, use a "debris spew" black-and-white image such as this:
    to only place instances on the surface where the image is white. You'd set the default Weight to 0.0, and then put an additive Image Texture on the Weight:
    By using a reference object (in this case I called it CenterNull), you can then move the CenterNull or rotate it to place the debris on the surface where you want it.
    Attached Files Attached Files
    Last edited by MonroePoteet; 10-30-2019 at 03:55 PM. Reason: Add "Debris Spew" placement
    you might be talking about this ? https://vimeo.com/247271531
    Oliver
    OD Tools Purchase Link: http://origamidigital.com/cart
    Vimeo Channel: https://vimeo.com/channels/850417
    Join ODRoot - https://www.odroot.com
    May 2006
    France
    4,102
    Quote Originally Posted by MonroePoteet View Post
    ...You then need to add all the Layers to the Instancer, but I don't think there's an easy way to add them all at once...
    This is something you can do in DP Instancer,
    the trick is to first select all objects in Scene editor, then CTRL click to add the instancer in the selection,
    so you can open the DP Instancer panel and click "Layout Selection".
    Denis.
    Mar 2018
    Denmark
    41
    Thanks guys!
    While admittedly not what I had hoped for (something real quick and easy), I have a lot to learn from your replies. Will try it all out for the sake of learning some new tricks. Much appreciated!
    Aug 2016
    a place
    1,983
    Quote Originally Posted by dpont View Post
    Denis.
    works well.
    not sure how to control all instance sources at once though, like random scale. cant multi select and set all values globally.
    May 2006
    France
    4,102
    ...not sure how to control all instance sources at once though, like random scale. cant multi select and set all values globally...
    A node setup has the advantage to be applied to all Referenced Objects,
    Or there's another trick in DP Instancer, add a first Object to be instanced,
    adjust settings and check "Copy Reference Settings" before adding the other objects
    as "Layout Selection".
    Denis.
    Aug 2016
    a place
    1,983
    Denis.
    how do you feel about a button that says "push changes to all other references" or (probably better) a checkbox that says "link references"
