Thread: Layout opening with 2 interfaces!
    Sep 2010
    UK
    23
    In Modeller, if I hit the 'Send to Layout' button, Layout opens two interfaces, one with the expected object and the second with a blank field. I'm using LW2015.3-64 which has been working fine until recently. I've tried stripping out the cfg's and also a reinstall. Has anyone else seen this? I'd be very grateful for suggestions.Click image for larger version.
Name:	Extra LW iteration.jpg
    Aug 2016
    a place
    1,929
    no, never had that one. windows shortcut fired twice is the only time thats happened
    Registered User Kaptive's Avatar
    Jan 2006
    UK
    761
    Hi. I've been using 2015.3 for an older project and have had this also. It actually happens both ways. Layout can open two instances of modeler too. It doesn't happen every time, but it happens often.
    I think it might be to do with upgrades to the hub, as I have 2019 installed too, though that is speculation (either that or windows alteration perhaps). I generally just close the blank one and leave the one that worked open for that entire session (with minimal issues), so forget about it. I don't think it's actually causing broader issues.
    Still a bit of an odd one though. I'm afraid I don't have suggestions to fix it, but I can share that it doesn't seem to break anything that a simple closure can't fix.
    Aug 2016
    a place
    1,929
    check the hub cfg.
    also, try running lw shortcuts with -0 flag and see if that helps
    Sep 2010
    UK
    23
    Thanks for the feedback guys. Please can you explain what you mean by '-0 flag'. Thanks for the reassurance Kaptive. Since overwriting the program my taskbar shortcut icons for LW are now suddenly showing blank-white!
    15,345
    Quote Originally Posted by Kaptive View Post
    Same here, but this happened a long time after installation, could be windows update or something in the 2019 installation mixing something up.
    Sep 2010
    UK
    23
    Yes, it crossed my mind that it could be a Win issue, and like you it reared its head a long time after installation. I figure though, if it is a Win issue, there might be more users affected by this too. And as with the earlier post, the problem shows both ways between Layout and Modeller. I still can't fathom the blank icons - all my others are fine. Yet another unexpected consequence of Brexit no doubt!
