Results 1 to 2 of 2
Thread: low res compression artifacts
Hybrid View
    Oct 2019
    Hong Kong
    3
    Hi, I'm trying to use the NDI SDK to send and receive low resolution video frames, e.g. 32 by 32 pixels, and I am seeing quite a bit of noise introduced by the NDI compression. Can you advise me if there is a better way to send low res frames without any loss of precision.
    I am using the C++ SDK example NDIlib_Send_Video to create a 32x32 frame, setting pixel[33] to (255,0,255,255) NDIlib_FourCC_type_RGBA. All other pixels are (0,0,0,255).
    I’m running a receiver based on NDIlib_Recv, color_format= NDIlib_recv_color_format_BGRX_BGRA (I want the RGB values) and allow_video_fields = false (assuming i want to force progressive)
    What I see on the receiving end, on the same laptop:
    received: video px 31 data B G R A: 0 0 0 255
    received: video px 32 data B G R A: 1 0 184 255 (preceding pixel, artifact)
    received: video px 33 data B G R A: 73 0 255 255 (target pixel, wrong colour)
    received: video px 34 data B G R A: 2 0 9 255
    received: video px 35 data B G R A: 0 0 7 255
    received: video px 36 data B G R A: 0 0 2 255
    received: video px 37 data B G R A: 0 0 2 255
    received: video px 38 data B G R A: 1 0 3 255
    received: video px 39 data B G R A: 0 0 1 255
    received: video px 40 data B G R A: 0 0 4 255
    received: video px 41 data B G R A: 0 0 4 255
    received: video px 42 data B G R A: 0 2 0 255
    received: video px 43 data B G R A: 0 2 0 255
    received: video px 44 data B G R A: 0 0 2 255
    received: video px 45 data B G R A: 0 0 2 255
    received: video px 46 data B G R A: 0 0 0 255
    So there is significant noise on the preceding pixel[32], the target pixel[33] has the wrong colour, and there is a little noise for the next 12 pixels. Attached screenshot of NDI Studio Monitor, where I expect to see one magenta pixel.
    Which settings should I use to increase the precision at this low resolution? Or should I send the frames in higher resolution and then resize after receiving?
    Aug 2015
    london
    264
    Quote Originally Posted by tomtobback View Post
    I would suggest you try 8 NDI pixels for each of your source pixels.
    So for 32x32 try sending 256x256. This may end up with the cleanest rendition of your source image.
