Thread: Newtek PTZ camera. pan tilt speed
    Feb 2009
    Tennessee
    192
    Is their a way to set a max PTZ speed in the camera so as to help the operator work more smoothly? We are goin gto be doing a parade live in a month and really need to be super smooth and not jerky.
    Common Gear Used:
    TriCaster: 40, 460, TC 1
    Time Warp TW42
    Cameras: Sony PXWX70, Newtek PTZ / HX
    Cable Solution:Coax HD_SDI & IP
    Newtek Spark HDMI
    Teradek Cube 105
    Chevy City Express Van
    Jan 2018
    Winter Park
    497
    I personally found the Xbox controller through ndi montior the be the easiest to track things when I played with their setup at NAB
    Registered User Red Dog Records's Avatar
    May 2008
    Northern California
    311
    I like the xbox controller too, but it means using BOTH HANDS to control the camera. You might want to try a joystick and see if you can create a custom configuration for it.
    We just used a Logitech Extreme 3D Pro Joystick for an event. We remapped the joystick twist to the pan of the camera and then messed around with limiting the range of the joystick in the logitech app to limit the speed.
    It worked pretty well considering we only spent about 30 minutes playing with it.
    Tricaster 460AE3 + Mini 4K
    Flypack: Router, switch, backup encoders, captioning devices, audio mixer, UPS, etc
    Cameras: Sony Z280, Z150, PTZ1, Multiple Spark & Bird Dog converters
    reddogrecords.com
