Thread: Clip maps on multiple parts of an object?
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,685
    Does anyone know how to add clip maps to multiple parts of a single object?
    For example, if you had 1 object made up of 6 boxes and each box needed a letter (text) on each box as a clip map.
    I have an animation using Part-Move and need to put a clip mapped letter (text) on each part.
    7,949
    Newer LW versions have Clip input exposed in Node Editor for every surface..
    May 2006
    France
    4,102
    If you have only a few parts in your object and use image mapping,
    the most simple way is to build a single image
    with letters side to side, and uv map each part UV
    side to side.
    Denis.
    Pessac
    5,117
    I was going to say exactly the same, Denis. You might want to use UDIM tiles to ensure maximum resolution for each letter.
    B
    LightWave 3D Trial Edition
