Thread: Motion blur is halfing my processors
    Mar 2018
    Perth, Australia
    124
    Angry Motion blur is halfing my processors
    Hi all,
    Got the strangest thing going on here. when I have a parametric shape and turn on motion blur, instantly half of my processors will work! I verified even with a new scene and it is reproachable.
    Can someone (preferably with dual processors) try and verify this? Open task manager go to Performance tab, view CPU's as Logical Processors. Next open Layout, add a null, change it to any shape, go to camera panel, turn on VPR and then with your left eye look on the CPU utilisation and with the right toggle motion Blur on and off and see if it makes a difference.
    My comp switches from 100% utilisation to about 26% - 30%.... and this is instantly! Also I can see only 1 processor is being used... It is almost as if LW switches to using no Hyper threading on only 1 processor.
    Here is a screenshot of my CPU utilisation when I simply click on the tick box to enable Motion Blur while in a VPR viewport.
    This only happens to shapes.... when I change the NULL to a volume, it works fine with or without MB.
    I use LW2018.0.7
    Pessac
    5,169
    It sounds almost as though motion blur on parametric shapes is not multi-threaded for some reason? Use the built-in bug reporter (Feedback in the Help menu) to log this.
    B
    LightWave 3D Trial Edition
