Thread: Lw 2018 yellow spots
    Hi
    Do you know why this happens? Same scene different frames and different results with that weird yellow spot when rendering the sequence. If I render that frame again that yellow spot can appear or not randomly
    either lights or geometry, turn lights off and by trial and error try to find it, check geo for two point poly's, non plainers etc
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,534
    If you are using 2019, try turning on de-spike, and give it a threshold of 0.2-0.3.
    Also,what is the specularity and roughness on the yellow surface?
    My Scripts for Lightwave
    Not only that surface, by the way. But its settings are those below
    And it's 2018
    Thanks both
    Mar 2012
    Socal
    436
    If you're in 2018, the principled shader could do some strange and incorrect things if you had clearcoat on.
    Feb 2009
    Prescott, IA
    1,534
    My recommendation is to go through the denoise workflow that should be in the online help, then.
