Results 1 to 9 of 9
Thread: Library compilation errors
    Oct 2019
    Paris
    2
    Exclamation Library compilation errors
    Hi everyone,
    I am beginning to integrate NDI in my company's software and i get compilation errors in Processing.NDI.Lib.h
    l43 : expected unqualified-id before string constant
    Compiler used : g++.exe (i686-posix-dwarf-rev1, Built by MinGW-W64 project) 4.9.2
    Unfortunately this is this only compiler i can use
    Thank you for your help in advance
    Registered User roddyp's Avatar
    Sep 2017
    UK
    54
    Do the SDK examples compile OK? If so, look at what you're including before the NDI headers - and have you missed a semicolon after a class...
    mingw should accept the __declspec(dllimport) directive in the header. I'm less sure about the __declspec(deprecated) one, though?
    Oct 2019
    Paris
    2
    Effectively, if i comment __declspec(deprecated) it compiles well. Where can i make a proper bug report for the developers to see ? (might get lost here)
    19,479
    The email address for communication related to the SDK is in its docs.
    Sep 2017
    UK
    54
    I actually hit exactly the same problem today using an older version of C++Builder.
    Quote Originally Posted by Ulysse View Post
    Rather than commenting it out, just add this before you #include the NDI headers.
    Code:
    #define PROCESSINGNDILIB_DEPRECATED
    This means you won't get any compiler warnings if you use deprecated functions.
    Alternatively you could try this, which uses the hopefully correct deprecation syntax for MinGW.
    Code:
    #define PROCESSINGNDILIB_DEPRECATED __attribute__((deprecated))
    No warranty expressed or implied with the second, as I don't have MinGW to try it.
    Software Engineer
    Jul 2006
    San Antonio, TX
    13
    So you mean this doesn't mean MSVC only?
    Code:
    #ifdef _WIN32
    #define PROCESSINGNDILIB_DEPRECATED __declspec(deprecated)
    #endif
    We'll get that fixed... :-)
    Brian
    Nov 2019
    Canada
    9
    Starting out with NDI. Was also getting this error in MINGW 5.3.0 32-bit and MINGW 7.3.0 (64-bit). Fixed by adding:
    I don't fully understand what's going on though...
    Sep 2017
    UK
    54
    Quote Originally Posted by rtavakko View Post
    Different compilers use different syntax to mark functions as "deprecated" (i.e. to warn you against using them).
    The NDI header files try and detect which compiler you're using, an then apply the correct syntax with a #define, but unfortunately there's a confusion if you're using non-Microsoft compilers but are developing for Windows.
    Nov 2019
    Canada
    9
    Thank you for clarifying that, it makes sense.
