Thread: Library compilation errors
    Oct 2019
    Paris
    Exclamation Library compilation errors
    Hi everyone,
    I am beginning to integrate NDI in my company's software and i get compilation errors in Processing.NDI.Lib.h
    l43 : expected unqualified-id before string constant
    Compiler used : g++.exe (i686-posix-dwarf-rev1, Built by MinGW-W64 project) 4.9.2
    Unfortunately this is this only compiler i can use
    Thank you for your help in advance
    Registered User roddyp's Avatar
    Sep 2017
    UK
    42
    Do the SDK examples compile OK? If so, look at what you're including before the NDI headers - and have you missed a semicolon after a class...
    mingw should accept the __declspec(dllimport) directive in the header. I'm less sure about the __declspec(deprecated) one, though?
    Oct 2019
    Paris
    Effectively, if i comment __declspec(deprecated) it compiles well. Where can i make a proper bug report for the developers to see ? (might get lost here)
    19,416
    The email address for communication related to the SDK is in its docs.
    Sep 2017
    UK
    42
    I actually hit exactly the same problem today using an older version of C++Builder.
    Quote Originally Posted by Ulysse View Post
    Rather than commenting it out, just add this before you #include the NDI headers.
    Code:
    #define PROCESSINGNDILIB_DEPRECATED
    This means you won't get any compiler warnings if you use deprecated functions.
    Alternatively you could try this, which uses the hopefully correct deprecation syntax for MinGW.
    Code:
    #define PROCESSINGNDILIB_DEPRECATED __attribute__((deprecated))
    No warranty expressed or implied with the second, as I don't have MinGW to try it.
    Software Engineer
    Jul 2006
    San Antonio, TX
    13
    So you mean this doesn't mean MSVC only?
    Code:
    #ifdef _WIN32
    #define PROCESSINGNDILIB_DEPRECATED __declspec(deprecated)
    #endif
    We'll get that fixed... :-)
    Brian
