Results 1 to 15 of 16
Thread: Reading a Text File.......
    Hi all,
    Hope someone can help me out with this is as it's driving me nuts.
    I'm trying to read a simple 2 line text file and then use that data to load an object into Layout.
    The loading of the Object file is all fine and dandy, but I'm having trouble finding out how to read a Textfile.
    I found something similar on the forums from a while ago, but struggling to get it to read the contents of the file. I'm sure I'm doing something very simple wrong.
    Current Code is below.
    Code:
    @warnings
    @version 2.2
    @name read_file
    generic
    debug();
    f = File("C:\\Users\\Public\\CKVFX\\output1.txt","r") || error("no file selected!");
    x=1;
    while(!f.eof())
    	buf = f.read();
    	if( !buf ) break; // or check whether string length is > 0
    	linevar = parse(",",buf);
    	line_001[x] = linevar[1];
    	line_001[x] = linevar[2];
    	x++;
    LoadObject("line_001[1]");
    f.close();
    The debug panel shows that the 'output1.txt' file is found etc. but the array etc. stays empty.
    Anyone have any ideas ? :-/
    TheMightySpud
    Okay, so I've now edited the code after realising a silly mistake.
    All the variables now get populated (confirmed by the debug panel). However, I'm still getting a 'Can't find Object File' error. So very confusing.
    Code:
    @warnings
    @version 2.2
    @name read_file
    generic
    debug();
    while(!f.eof())
    	buf = f.read();
    	line_001 = linevar[1];
    	line_002 = linevar[2];
    LoadObject("line_002");
    f.close();
    TheMightySpud
    May 2006
    France
    4,174
    I think that line_002 is a string variable,
    so no need "" in LoadObject().
    Denis.
    Told you it was something simple. lol.
    Works great, thanks Denis
    TheMightySpud
    Okay, so hopefully just one last question. Is it possible in lScript to 'force' the script to read whitespace?
    I'd rather not have to go through a bunch of renaming to remove said spaces from file/folder names :-/
    TheMightySpud
    May 2006
    France
    4,174
    Quote Originally Posted by TheMightySpud View Post
    Okay, so hopefully just one last question. Is it possible in lScript to 'force' the script to read whitespace?..
    Do you get issues with white spaces in folder or filename?
    Should not be a problem, in Lscript or Python.
    Denis.
    Oh dammit. lol. Just as I saw this reply I noticed that my generated text file didn't have the extra carriage return added to it. All fixed now, silly thing. Thanks for the reply(ies) though Denis, really appreciate it.
    Okay, so lscript syntax is driving me insane........any ideas why the following 'case' block isn't working properly? It just 'jumps' to the Default case every time, even though the data for 'line_001' is present and matches the case labels.
    The data is being pulled from a text file in the format : <assetType>,<fullAssetPath>,<assetFolderPath>
    I can get it working using a crapload of if/else statements, but figured a switch()/case method would be a little more elegant.....
    Code:
    @warnings
    @version 2.3
    @name read_file
    generic
    AutoConfirm(1);
    current_dir = getdir("Content");
    f = File("C:\\Users\\Public\\CKVFX\\tempText.txt","r") || error("no file selected!");
    while(!f.eof())
    	buf = f.read();
    	line_003 = linevar[3];
    ContentDirectory(line_003);
    switch(line_001)
    case staticObject:
    	info(line_002);
    	LoadObject(line_002);
    	break;
    case genericTexture:
    	info(line_002);
    	myimage=loadimage(line_002);
    	break;
    default:
    	//info("No Matches found!");
    	info(line_001);
    	break;
    f.close();
    ContentDirectory(current_dir);
    AutoConfirm(0);
    TheMightySpud
    May 2006
    France
    4,174
    I never used text string in switch()
    did you try "staticObject" as case.
    Denis.
    Certainly did, does the same thing. Going to try using integers instead and see if that works.
    TheMightySpud
    Well, integers didn't work, I suspeect because the data being read from the text file is being handled as a string? (replaced the first line of the text file with 1, changed the code to case 1,2 etc.) and still just jumps to the 'default' state.
    May 2006
    France
    4,174
    Absolutly, except binary reading, all is string,
    you need integer()
    Denis.
    Gah. Now I need to figure out how to take the string data from the text file and turn it into an integer. *bangs head on desk*
    Pessac
    5,180
    As Denis says, no? Use integer(string)?
    B
    LightWave 3D Trial Edition
    Ah sorry, completely misunderstood what Denis posted. My bad.
