Results 1 to 14 of 14
Thread: Something that should be really simple................
    ......but I'm having such a problem finding anything in the SDK docs about this.
    How do you simply load an object into layout using Python?
    Working on something and this is my last stumbling block.
    TheMightySpud
    Pessac
    5,112
    I'm no Python expert, but I would say you want to use a LightWave command through Python. Check the SDK docs for Loading and the Command List...
    B
    LightWave 3D Trial Edition
    This is petty much my problem, I'm finding the docs to be absolute garbage, I've been through numerous times and can't see anything to do with loading an object. :-/
    May 2006
    France
    4,099
    in the SDK html "commands" folder, layout.html
    ->Object,
    LoadObject sfilename
    Also in Layout/Utilities/ a "Save Cmd List" button will save a file with all available commands.
    There are several sample python scripts in Generic folder,
    for examples of Command synthax.
    Denis.
    I've been looking at the LoadObject command but can't for the life of me figure it out. Might be just tired. Giving up for today.
    May 2006
    France
    4,099
    In support/scripts/Python/Layout/Generic
    there's a Add_Null/py script, good template for beginning,
    see how the AddNulll command is handled.
    Denis.
    May 2006
    France
    4,099
    there's also a Proxi with PRIS (see the online Lightwave Python doc)
    lwsdk.pris.layout.cs.loadobject(filename)
    lscript has also a proxy, this is even simpler, except the double backslash,
    @warnings
    @name "Load Object"
    generic
    LoadObject("D:\\3D\\LWContent\\Objects\\Box.lwo");
    Denis.
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,534
    It appears that you have to go through the following steps:
    Code:
    import lwsdk
    def process (self, ga)
       name = "myfilename.lwo"
       result = ga.evaluate(ga.data, "LoadObject %s" % name)
    (This is taken from the 'add_scene_comment.py' example.)
    or something similar.
    you could also use the (much maligned) PRIS, which has a proxy for the LoadObject command...
    Code:
    My Scripts for Lightwave
    This is now driving me insane. I've tried both of the solutions provided by Kryslin, but still not doing anything. I'm not getting any errors, but the scripts don't load in the object.
    I'm probably doing something really silly wrong.
    Here's the 'non-pris' version of the script.
    Code:
    #! /usr/bin/env python
    # -*- Mode: Python -*-
    # -*- coding: ascii -*-
    This is a LightWave Generic plug-in that adds a new Null object
    and positions it at <0, 1, 0>.
    import sys
    import lwsdk
    class Load_Object(lwsdk.IGeneric):
        def __init__(self, context):
            super(Load_Object, self).__init__()
            def process (self, ga):
                name = "F:\StaticModels\Objects\Aset_qkduW_ZTool.lwo"
                return lwsdk.AFUNC_OK
    ServerTagInfo = [
                        ( "Load_Object", lwsdk.SRVTAG_USERNAME | lwsdk.LANGID_USENGLISH ),
                        ( "Load Object", lwsdk.SRVTAG_BUTTONNAME | lwsdk.LANGID_USENGLISH ),
                        ( "Utilities/Python", lwsdk.SRVTAG_MENU | lwsdk.LANGID_USENGLISH )
    ServerRecord = { lwsdk.GenericFactory("LW_LoadObject", Load_Object) : ServerTagInfo }
    Can anybody see where I'm going wrong? :-/
    TheMightySpud
    May 2006
    France
    4,099
    I think you need at least the declaration of the __lwver__
    Denis.
    May 2006
    France
    4,099
    Also the double backslash because it's a special character.
    Denis.
    May 2006
    France
    4,099
    ...And finally, the def process should not be indented to def _Init.
    Denis.
    May 2017
    Lampertheim, Germany
    130
    I don't know if this is the solution, but I think your indentation is wrong.
    The script does nothing visible... because the "process is declared as a sub-func of __init__
    I think it should look like:
    Quote Originally Posted by TheMightySpud View Post
    Code:
    import sys
    import lwsdk
        # the complete process-func goes 4 spaces to the left, so process is no longer a Sub func of __init__
    ServerTagInfo = [
    Take a deeper look at your filename. in win-based Environments the \ is represented as \\
    I hope this helps you any further
    Regards,
    Kanuso
    You need only 2 lines of code to do this...
    Code:
    import lwsdk
    lwsdk.command("LoadObject C:\\myfolder\\Objects\\MyObject.lwo")
    Single shot plugins (AKA generic plugins) don't require Lightwave's fancier classes and functions, you can skip them alltogether. Unfortunately the LWSDK's documentation is only in place as a reference... it doesn't do much to help you take advantage of the sdk.
    If you find yourself getting stuck and its a simple matter, i'll try and make sure you get the info you need.
